Results 1 to 10 of 12
Thread: My turboed NA 4.2 GU
    Apr 2011
    so this is my DX as i bought it
    DTS turbo kit - non intercooled
    3" exhaust
    snorkel
    2" ironman lift
    duel batteries
    31" duelers
    im pretty novice when it comes to cars (especially diesels!!) so after reading a few threads about adding a turbo to the NA motor i was becoming paranoid about blowing the NA motor, so i decided first on the list was boost and pyro gauges. once installed i headed up princes hwy to see what she would do!! at 100ks up a steep hill its maxing out at 12psi and nearly hitting 500c on the pyro.
    since then i have bought a set of 35" centipedes, so would expect EGTs be even higher now
    with those temps and the now bigger wheels, im pretty sure i need to intercool the beast to give it a better life! just trying to find out how to go about it, any input is appreciated, cheers!!
  2. The Following User Says Thank You to TDR For This Useful Post:
    AB (6th June 2013)
    Wind the boost up a little it may help. Try going to 14psi
    22 Post(s)
    Hey mate.
    If you get a chance there is a thread for EGT logging. If you did a test on a hill that could be easily found by other members in the area post up your stats.
    Cheers.
    http://www.nissanpatrol.com.au/forum...T-data-logging
    96 GQ coil/Cab
    08 G6eT
    Apr 2011
    wont upping the boost increase the inlet temp therefore increase EGT? 12psi is as high as i wanted the boost (just going off other posts) for piece of mind
    14 won't be to bad. More air in means a leaner mix which may slow the temp rise a little. If it doesn't help then you can always change it back.
    An intercooler will help a lot. Front mounts work well and are simple.
  7. The Following User Says Thank You to nissannewby For This Useful Post:
    TDR (6th June 2013)
    Apr 2011
    ok i might give it a try, seems like its already pretty lean though.. doesn't give a single puff of black smoke
    Apr 2011
    also the turbo barely spools unless ive got my foot pretty deep. On a flat road it will only hit about 6psi on gear changes then sit at 0 cruising at 60 in 4th.. My mates ZD30 is nearly always on boost!! Could this be the way it was tuned? It was used to pull a caravan, a mate suggested they bring on boost later if its a tow car so that your not flying through the gears real quick
  10. #8
    Jan 2013
    Quote Originally Posted by TDR View Post
    wtf. . . . lol. earliest boost possible is always best.
  11. #9
    Apr 2011
    yeah it comes on pretty late compared to my mates zd30, maybe needs a re-tune
  12. #10
    What sorta exhaust has it got.
    3", but straight threw or mufflers?
    And what rpm is the turbo coming in at?
    Owner of
    Westy's Accessories
