Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 51
Thread: Stupid question time
    Western suburbs of Melbourne
    12 Post(s)
    With auto hubs or it pays to reverse to stop axle wind up after a session
    So after driving in 4hi/lo I'll need to reverse a bit then put it back into 2wd.
    But is this only when in auto on the hubs or the same if I had them locked.
  2. #12
    177 Post(s)
    Reversing in 4 low or hi should be no dramas. I used to reverse a mates fishing boat up a slightly steep-ish driveway in 4-low in my Nav. Makes it easier on clutch too.
  3. The Following 2 Users Say Thank You to Hodge For This Useful Post:
    BigRAWesty (5th June 2013), MEGOMONSTER (2nd June 2013)
  4. #13
    Nah put into 2wd then reverse. It forces your hubs to unlock, otherwise they may still be locked while you drive away.
    If you're happy and you know it tap a post!
  5. The Following User Says Thank You to Winnie For This Useful Post:
  6. #14
    Patrol Guru TimE's Avatar
    Canberra
    But..... You should Lock your Auto hubs or they may disengage.
    ..... found this out the hard way when stuck in a muddy rut unable to get any backward movement, the auto hubs had disengaged. Get out in the mud and snow and lock the auto hubs, rearward movement is then available. This resulted in my rule that whenever I am in sand, snow or mud the auto hubs are manually locked for the duration of those conditions. (Of course normal rules about not using 4wd on tar or "hard" surfaces apply)
  7. The Following 2 Users Say Thank You to TimE For This Useful Post:
  8. #15
    Yeah its called wind up, you need to reverse say 50 mtrs, sometimes more to "UN WIND" the drive train.
    It releases all the tension { Pressure if you like} from driving forward.You have no doudbt heard the term back lash
    effectivly wind up has removed all your back lash, reversing unwinds your axles releasing the tension, restoring back lash
    and allowing you to select 4 hi etc, hope that made sense. Wind up is wind up be it hubs in auto or fully locked IMO
  10. #16
    Oct 2010
    Old Bar, NSW
    I don't have auto hubs so can only comment on manual locking hubs.
    Hubs are still locked;
    When it is no longer necessary to use 4WD I select H2, most times the 4WD light is still on, I drive forward and most times it goes off, if not just do a left and right on the steering wheel the transfer case disengages and the light goes off.
    Don't drive it hard, just normal driving on any surface. Never had a problem with it disengaging. Once the light is off the wind up is gone so drive away.
    50 metres plus is a long way TD!
    Macca
  11. The Following User Says Thank You to macca For This Useful Post:
  12. #17
    Beginner dubizzle@bresson.org's Avatar
    Mar 2011
    Does it happen with a manual gear box or with an auto one?
    Feb 2011
    Shed
    45 Post(s)
    Quote Originally Posted by dubizzle@bresson.org View Post
    I don't think the gearbox makes a difference just the auto hubs?
  14. The Following User Says Thank You to growler2058 For This Useful Post:
    MEGOMONSTER (5th June 2013)
  15. #19
    Do you know what back lash is? It doesn't matter whether your in 4wd, 2wd hubs locked or unlocked, as soon as you start to drive (engage clutch) the back lash has been taken out.
    Wind up is completely different. If you constantly drive in a straight line when in 4wd with no wheel spinning then it shouldn't occur (unless your Tyres are bigger on one axle). It tends to happen when steering and in 4wd, as everyone knows the outside turning wheel has to turn faster than the inside wheel so the front drive shaft wants to spin faster than the rear (wind up).
  16. #20
    So unless your doing NASCAR style tracks the wind up should be minimal?
    I to select 2wd when not needed, but as soon as I leave the formed road/track its 4wd as it saves tracks and keep the nicer for longer..
    Owner of
    Westy's Accessories
