Results 21 to 30 of 42
Thread: Power A/T Button
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    power mode
    used for rapid acceleration up hill,up shifts from 1to 4thgear when od switch is off,occur automatically
    auto mode
    used for eco driving
    hold mode
    provides feeling of sporty driving with manual trans when used in combination with select lever and od switch also used for standing starts,on slippery,snowy ,sandy roads
  2. The Following 2 Users Say Thank You to Sir Roofy For This Useful Post:
    Dave_H (10th April 2014), Sgucul (26th May 2019)
  3. #22
    Patrol God nowoolies's Avatar
    Perth
    it does well ill be a monkeys ....... i got the button as well and i havent felt any change no matter what i do , but the light comes on and that makes me happy
    lmao kiss method and im happy hahahaha
    nowoolies
    HELL NO !!!!!!
  4. #23
    TRAFALGAR VIC
    35 Post(s)
    Well then try it going up hill as you start to go up put it in power mode
    it should shift down and scoot up the hill quicker and smoother
    you can do the same with the od button
  5. The Following User Says Thank You to Sir Roofy For This Useful Post:
  6. #24
    Feb 2011
    well that make good sence to me
  7. #25
    Expert 1peter's Avatar
    May 2011
    Caboolture QLD
    Quote Originally Posted by nowoolies View Post
    nowoolies
    Ditto, nothing/zip other than it takes off in 2nd when i switch it to hold.
  8. #26
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    Hmmm ... get them checked maybe?? When you switch it to power, as opposed to what the word suggests, you don't get more 'power' but it should definitely drop back a cog easier with less throttle input - that is, when off and going up hill, you need to depress the peddle in about half way (let's say) to get it to kick back a gear, but with it set to power, you only need to depress the peddle slightly for the same result. Same goes for accelerating - will hold the gear longer before up changing. Mine is nearly 20 years old and works just as described - I use it each and every time I tow for instance.
  9. #27
    Perth
    well i tried it out again today going into town
    i forgot it was there
    and i noticed a healthy change in take off and gear change
    never noticed it last time maybe because the bus was new
    got 24,000klm on it now run in a bit
    now gotta find a muddy hill to try the other side of the button out
    HELL NO !!!!!!
  10. #28
    Expert twisty's Avatar
    May 2011
    ACT
    I LUV the A/T switch :-) Found it a while ago (thanks to this thread). Power is always selected around town (yeah .. I know ... fuel ... environment ... etc ... don't care) cause I enjoy surprising the "P" platers going uphill ;-) oohhh ... and at the lights ... hehe ... and in that tight spot on the dirt ... aaahhh, memories.
  11. #29
    May 2011
    Caboolture QLD
    But when you watch the revs and switch the button does it make any difference at all ?? I've tried mine by driving along and keeping an eye on the revs and switching the button from Power to Auto and nothing happens ?? If i put it in hold i can take of in 2nd (i think) other than that, nothing, nadda, nil, stuff all. What model is your Patrol and have you tried holding the throttle and watching the tacho while switching the button ??
    Quote Originally Posted by mudtrolluk View Post
    My auto has a 3 way rocking switch, with lights built in;
    Up is "Power" orange light and lengthens the shift paten i.e. allow engine to rev higher before changing up and will kick down quicker to lower gear when accelerating , good for towing up or down hills.
    Middle is "Auto" no light, standard shift paten, however if you boot it, it will change to "Power" on its own and show orange "Power" light until you back off.
    Down is "Hold" green light shortens the shift, so will change gear to a higher gear quicker helping with traction and restricting engine power.
    In my (NAF)Haynes manual there is a fault code for the Orange light, when the ignition is turned on the light flashes.
    Hope this helps, phil.
  12. #30
    Aug 2011
    Hi Guys,
    As far as i know that switch only offers two modes, Power and Hold.
    In the AT or Middle position it will automatically select the best mode, Either HOLD or POWER.
    Thats why you cant feel the difference when changing from AT to Power.
    If you feel the difference when taking of in HOLD mode, hold is working.
    When in AT or Power mode it will take of the same, always from 1st, the only difference is Power will hold it in power mode, where AT will selcet the best mode alone.
