Results 1 to 10 of 14
Thread: Floor Cracking :(
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Floor Cracking :(
    Hi guys and girls, found a crack in the flooring under the drivers passenger seat
    Looks like a plate for the front bolt closest to the door that hold the back seat in.
    I have a body lift and have heard of body lift causing cracking but assumed that any cracking from the body lift would happen around the lift.
    Has anyone else experienced cracking in this spot
    Can't really see the crack itself in the pics and the motor oil there doesn't help ( don't ask ) but is the reason I found the crack
    Todd
    wont be caused by a Body Lift. when the body lift causes a crack its generally around a mount block. My two rear mounts actually punched through the floor pan!!!
    go to an exhaust joint and ask them to dab a bit of weld on it for you. Roll back the carpet before it goes on the hoist though.
    Aug 2010
    17 Post(s)
    Thanks Darren, didn't think it was caused from the body lift..........mmm wonder what caused it
    84 Post(s)
    I have seen cracking continue after welding, so it might pay to drill a small hole at each end of the cracks beforehand.
  5. #5
    Tend to agree with Darren is that captive nut OE
  6. #6
    Patrol Freak Parksy's Avatar
    Jan 2013
    Nowra NSW
    5 Post(s)
    Agree with stop drilling at the end of the cracks. If you can use some fine sandpaper rolled up to smooth the hole afterwards that would be perfect. Then weld to close it all up.
  7. The Following User Says Thank You to Parksy For This Useful Post:
    NissanGQ4.2 (27th May 2013)
    Just use bigger drill bit to counter sink[de burr] it
    Seats aren't loose are they ??
    Aug 2010
    17 Post(s)
    Don't think they are John, but I will check them 2morrow
  10. #9
    Onlly saying that as constant rocking over its life may be the cause.
    I removed that seat behind the driver in favour of my Engel.
  11. The Following User Says Thank You to threedogs For This Useful Post:
  12. #10
    22 Post(s)
    Is that crack through a weld or next to one
    96 GQ coil/Cab
    08 G6eT
