Page 53 of 177 FirstFirst ... 5152535455 ... LastLast
Results 521 to 530 of 1768
Thread: Ask all your general ( none related forum ) computer questions here
  1. #521
    Thanks for your help mate, I'll read through this again tonight when I get home and let you know....
    Its the wireless that is causing issues. PC plugged directly in to the modem is trouble free!!!
    ok could be a driver issue with your computer, perhaps the modem needs a firmaware upgrade, but we can go through a few things and change some settings im sure i can sort ya out mate
  2. The Following User Says Thank You to rusty_nail For This Useful Post:
    AB (23rd April 2013)
  3. #522
    It's an old clunky xp too...lol....I desperately need a new computer!
  4. #523
    gimme a call tonight, i can probably help you out with that if you are after a computer.
  5. #524
    Patrol Freak lorrieandjas's Avatar
    Brisbane
    Sounds like time for an Apple? (Waits for the rocks to be thrown now!).
    Jas
  6. The Following User Says Thank You to lorrieandjas For This Useful Post:
    Bob (23rd April 2013)
  7. #525
    Brisbane
    hi mate,
    sorry i didnt get onto this last night but i was at a party. and im sorry if some things have already been explained BUT sounds like your describing a mix of two problems here your saying your internet is hanging but think its your wireless? is your internet hanging, or is the wifi dropping out? im sure you know these things but:
    if telstra have given you a static IP adress that has nothing to do with your local network. arp -a only shows you your local IP adress, thats the IP of the computer. however that IP is just the IP within your local network(so from the modem down). the static IP telstra have given you is the modems IP adress on the telstra network. my computers IP on the NSWDET is 10.17.221.232, this is dynamically assigned be the DHCP(thing that hands out IP adresses). however the departments Ip on the WWW is 153.107.33.155 and that im fairly certain is static(it doesnt matter but i hope you get my point).
    SO! you also mentioned that you may have needed to install a driver for you modem, do you think that because the modem came with a CD? usually the CD contains a utility which gives you a simple interface to talk to the modem, however you dont need it! to access your modem goto command prompt and enter ipconfig, a whole heap of info will come up but what your looking for is the default gateway. this is the adress of your modem on your local network(LAN) typically it will be 192.168.0.1 or 192.168.1.1, but i think telstra routers are set to use the 10.0.0.1 IP range.
    bear with me, ill get to it in a sec, just helping you understand.
    IF your problem is with the wireless, you will be able to fix the problem by doing the following:
    to check if your modem is configured properly goto your internet browser, and in the adress bar(where you would put nissanpatrol.com.au usually =P) type the default gateway adress in(remember 192.168.0.1 or what ever it is). from there you can change things like the wifi connection type, from G to N, or the channel if your router is only a G type router. also check your device has the correct user creds on the connection page.
    BUT if wifi is not your issue you may want to expore some other possibilities:
    1. do you have a line filter on your modem? if yes is it faulty? if no definately get one!
    2. plug your house phone into the wall directly, is there static on the line? if so telstra need to investigate faulty wiring to your house.
    apart from that i would be happy to go through other more complicated troubleshooting methods on the phone with you if you like. shoot me a PM with your number and ill give you a call and sort it out for you.
    Hi mate - for what it's worth (and you've given AB the command to find his default gateway) Telstra uses weird random addresses for their gateway - mine for example is 192.168.1.68??? The issue may well be related to 802.11n be set as default - I have seen this as an issue many times particularly with iPhones and older PCs.
    Jas
  8. #526
    Quote Originally Posted by lorrieandjas View Post
    Jas
    Apple shmapple.....NEVER!!!!!!!!!!!
  9. The Following User Says Thank You to AB For This Useful Post:
    taslucas (23rd April 2013)
  10. #527
    Jas
    precisely!
  11. #528
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    bluestacks is just a utility that assists the bluetooth to run.
    Thanks for the bump Clunk
    Nic, the Bluestacks I am referring 2 is actually an Android emulator for PC so I can run Mobile Apps for the kids on the PC
    http://www.bluestacks.com/
    For the time being I have given up trying to get the software 2 work
  12. #529
    Oh ok sorry bud ill look into it some more for ya and see if I can't work it out
    Tappin
  13. #530
    84 Post(s)
    What is that little eye symbol at the right hand side of the password box when I sign in? It sometimes appears and disappears.
