Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Got my GU, annoying door switch problem
    177 Post(s)
    Hey folks, picked up my 2009 GU ST wagon this morning. Half way home, door open light popped up on the dash. All doors were 100% shut. Got home tried pushing in all switches manually one by one. None of them seemed to set off the light on dash and/or the interior light. Very annoying. Dealer reckons he didn't have that issue or see it at all.
    I know it's most likely a rooted switch on one of the doors, but anyone had such issues? It's just annoying not knowing which door/switch it is.
    Legendary happygu's Avatar
    It will be one of the rear doors....
    Place a couple of washers under the small door switch and see if that fixes it, but sometimes it is the big door.
    Mic
  3. The Following User Says Thank You to happygu For This Useful Post:
    Hodge (23rd May 2013)
    Patrol Freak gaddy's Avatar
    redlands
    X2 mine gives the odd flicker every now and than
    Steve
  5. The Following User Says Thank You to gaddy For This Useful Post:
    177 Post(s)
    See this is why I love forums... Almost instant problem solving replies by knowledgeable people. Mic I owe you one. The fact that it could be one of the rear doors never crossed my mind, as I didnt think there was a switch back there. Cheers mate!
  7. The Following User Says Thank You to Hodge For This Useful Post:
    gaddy (24th May 2013)
  8. #5
    Legendary NP99's Avatar
    Feb 2013
    Broadford VIC
    It's on the small rear door on the lower closing side.
    1999 GU 4500 dual fuel
    Il dado è tratto
  9. The Following User Says Thank You to NP99 For This Useful Post:
  10. #6
    It is a very common problem with GU's, especially with bigger tyres on the rear door ...I have had it with 2 out of 4 of mine......
    Mic
  11. #7
    177 Post(s)
    Yup, checked it today definitely the left rear (smaller) door switch. Thanks folks. Just seems like the switch is spaced too far into the door.
  12. #8
    Advanced Country_GU's Avatar
    Yeah get a magnet, cut two peices off it and stuck them one on the other where the switch strikes, fixed mine, 5c (maybe even free) fix
    Maroon 2000 GU II ST
    04 ZD30 heart transplant half bulletproofed!
    Winning!
  13. #9
    Advanced ben 4.2td's Avatar
    northwest coast Tasmania
    I have the same problem, but it is the larger door, even though it is shut properly. I usually open it again and slam it hard and it fixes the problem, but will look at fixing it properly now are reading the above advice
  14. #10
    Feb 2013
    Broadford VIC
    Quote Originally Posted by ben 4.2td View Post
    Careful when slamming, it can do damage to the horizontal cracking along the latch inside near the window. Hope that make sense.
    Il dado è tratto
