Page 10 of 13 FirstFirst ... 89101112 ... LastLast
Results 91 to 100 of 128
Thread: Black rims
  1. #91
    Thomastown, Melbourne
    6 Post(s)
    Just sent request off and should not be too long before I get an answer??
  2. #92
    6 Post(s)
    OK he just got back to me and said those tyres you mentioned Ian are way over priced for what you get and said he can get a tyre called the Black Lion that is hard wearing and has a very heavy load rating..
    He said he can do 6 tyres and rims for $1600
  3. #93
    Expert GU CAMPER's Avatar
    Sheffield Tasmania
    Oh they only have 0 and neg20 off set
    Is that the infinity wheels. The coyote black that I ordered on Friday are 16x8 with negative 25 offset
    Was told they also come in 0 offset
    NEVER USE A SNATCH STRAP ON A TOW BALL AS DEATH MAY RESULT
    GU 2005 Cab Chassis Ex Telstra POD, Set up for Remote Touring and Play
  4. #94
    6 Post(s)
    This is the pattern? ?
  5. #95
    Apr 2013
    Mount Nasura
    Thanks Cuppa, you are pretty much receproacting my thoughts.
    If push comes to shove then I definatly want something thats going to be repairable out on the tracks, plus at the end of the day I think black steelies look the business!!!
    Would be interesting though to wack a pair of steelies and alloys on the scales to see just how much of a weight difference there is.
    2008 GU ST Bog stock and no smoking barrels!
  6. #96
    6 Post(s)
    Both bloody heavy!!!!!!!!!
  7. #97
    178 Post(s)
    Black Lion Powercode BS80
    Thanks BA, $1600 for 6 wheels & tyres is a very attractive price, over $500 less than if I bought the ROH rims George has been quoted on & the Bridgestone D697's at my locally quoted price. That is a lot of savings but I reckon I might give it a miss. I may be crazy & missing out on a real bargain, but basically I'd rather buy tyres that I've heard of, & can get replacements for relatively easily in outback woop woop should the need ever arise. Thanks for checking it out though. Did he give a price on just the ROH rims at all?
    Cuppa
  8. #98
    178 Post(s)
    Quote Originally Posted by Beni C View Post
    Other's will know, I'm only guessing, but I wouldn't be surprised if on a 16" rim & tyre combo that a fair bit more of the total weight would be the tyre, especially if running LT tyres.
    Cuppa
  9. #99
    178 Post(s)
    And just to throw more fat on the fire (& thinking aloud in case anyone should think I'm trying to contradict what they've already told me - I'm not, just trying to process 'new info') ...... a couple of the wheel places I've rung today have informed me that the stock Patrol 16x8 offset is Pos 10mm (as others here have said) & that to run 265's I should get a zero offset wheel, not a neg 13mm. I wish I didn't keep getting conflicting bloody info! I've had enough of it, & know that neg 13 will do the job 'cos I've seen 'em on Maccas truck, besides if they stick out a tad more than they really need to so what, doesn't really matter does it? Neg 13mm moves the wheel 23mm 'outward' rather than the 10mm 'outward' a zero offset would achieve. 10mm seems a bit too close If I went with zero & got rims & they rubbed I'd then be up for getting them machined & rewelded plus repainted which would not make me a happy chappy whereas having a little extra space between my tyres & the chassis does no harm.
    SO....... George can the place you got quoted on the ROH's supply tyres too, & if so could they price a package deal on rims plus 265/75LT Bridgestone D697's (fitted & balanced if possible) or do you think i'd be better getting them fitted locally in case I get any post fitting 'wobble' problems?
    Cuppa
  10. #100
    178 Post(s)
    Nobody rang eastern wheel works they are made with 10mm hubs instead of 4-6 like most sunnies
    any offset you want. plus you wont look like everyone else. If i wanted load carrying I ring them at the
    drop of a hat
    I did ring them TD, but seem to have 'lost' the response I thought I'd posted here (I know I wrote it, but perhaps I closed a window without actually posting it).
    $340 per rim is out of my league unfortunately, no matter how good they are.
    The bloke there seemed pretty good to talk to & even advised me that I'd be better off buying off the shelf if I could. He mentioned those 2100kg mine spec 16x7's I referred to earlier & reckoned I'd have no problem running 265/75's on them. He also said that he could change the offset in any wheels for $70 each.
    When I told him I'd be running at close to 4 tonne, his view was that the 1200kg rated wheels like ROH & King should be quite adequate particularly as their rating allows for some leeway.
    Cuppa
    Eastern Wheel works 6 spoke 'Sunset Country' steel wheel
