Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Engine too loud
    Expert Bulbous's Avatar
    Apr 2011
    Dubai
    Qatar Hmmmm!
    Are you running Siam sand tires?
    Steve
    2011 Patrol Safari 4.8 (Fitek)
  2. #12
    I would have thought you had a viscous coupling hub on your 4x4 fan.
    The fan shouldn't be fixed, do you have a shroud on radiator??.
    Maybe someone fitted a fixed Steel 6 blade fan, very noisy option.
    will see what pics reveal first. But fans very noisy.
  3. #13
    Dec 2012
    Quote Originally Posted by Bulbous View Post
    Qatar Hmmmm!
    Not yet. I was told they are not really any better than HT on the dunes. And that they are horrible on road. Is that true?
  4. #14
    Dec 2012
    Viscous coupling meaning fan speed not related to engine speed? Will post pictures up soon.
  5. #15
    Apr 2011
    Dubai
    Quote Originally Posted by sugu View Post
    Pretty much - they're only good for inflating to 60 PSI and doing burn outs. Actually at 60 PSI, they offer almost zero rolling resistance so they're good for driving fast on road, but the handling is pretty bad. Especially when they're cold - wobble like crazy.
    I would never fit them
    Steve
  6. The Following User Says Thank You to Bulbous For This Useful Post:
    sugu (19th May 2013)
  7. #16
    84 Post(s)
    If you use an underbody coating, make sure not to get it too close to heat from the exhaust system.
  8. The Following User Says Thank You to mudnut For This Useful Post:
  9. #17
    Sep 2010
    I have stripped the inside and applied Dynamat Extreme throughout entire floor pan/ firewall as far as possible. Frustrating job but great results
  10. #18
    Dec 2012
    Quote Originally Posted by Goldifox View Post
    and expensive too. Did you use it on the doors/roof?
