Page 4 of 13 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 128
Thread: Black rims
  1. #31
    Legendary Alitis007's Avatar
    15 Post(s)
    I got quoted the following prices this morning. Wheels are neg 13 offset.
    I'm favouring the Dynamic round hole wheels at the moment.
    I like those dynamic wheels mate who sells them?? I was chasing up some rims today and was trying to get them direct and cut out the middle man, 1 manufacturer came to the party the other will need some more time i think..
  2. #32
    brisbane
    I've cracked the welds on two dynamic rims previously, the only way I knew was it caused the tyre to go flat! But I'd have rather that than loosing a tyre that's for sure.
    both were replaced and one was even outside of warranty period so good service but I got rid of them as I had no confidence in them.
  3. #33
    15 Post(s)
    Has any one used the CSA Ranger steel rims? And if so are they any good??
  4. #34
    178 Post(s)
    The quote I got was from our local Tyrepower.
    Megatexture, just when I think I'm arriving at a decision, you manage to throw it all up in the air again! Lol. Which Dynamic wheels did you have & what sort of usage? As far as looks go I probably prefer the slightly more open triangular cutouts of the ROH or Kings, but was heading the Dynamic round hole way only because I thought that the round hole design might be a bit stronger (greater metal to hole ratio, & no 'corners' in the holes possibly making cracks less likely to start?). But it sounds like yours cracked on the rim section rather than the wheel centre.
    I would've considered the Pro Comp wheels too, but their load rating is too low compared to the others (under 1000kg whilst the others are 1200kg).
    Cuppa
  5. #35
    178 Post(s)
    Alitis, if the CSA ranger wheels (Mullins) were available in the size I need (16 x 8 neg 13mm offset) I'd go with them as they have a higher load rating than any others I've seen (1500kg) , but unfortunately not available in this offset. Neg 26mm was the closest option I think.
    Cuppa
  6. #36
    Expert benno77gu's Avatar
    Nov 2012
    tumut nsw
    hi fellas im keen on the round hole rims in cuppas pic i have 285 75 16 big horns ready to go, what off set rims would be best, its for an 01 gu wagon ,thanks fellas
    01 gu td4.2t wagon factory turbo 2" lift, 3" exhaust,snorkel,awning,uhf,egt & boost gauges,16"black round hole dynamic rims with 285 bighorns with more to come, ,air compressor,rear led work lights,winch, ready to fit up
  7. #37
    15 Post(s)
    Black rims
    In the catalogue they have 0, 20 ,26
    http://www.csadirect.com.au/fitment-...taBankCat1Id=3
    But i did find one to suit a hilux pos 13 but i'm not sure if the center hole diameter is big enough and only in 16x7
    I'll keep looking thru it tho Cuppa, the problem is our PCS is 138.7 and the other 16x8 neg 13 wheels all have a 150.9 PCD i'll keep you posted mate..
  8. #38
    15 Post(s)
    Quote Originally Posted by benno77gu View Post
    I'm trying on sat of 285 75 16 with a neg13 offset and i'm stock hight on my 99 trol and i don't rub but i'll need to remove my mudflaps so i don't loose them lol
  9. #39
    15 Post(s)
    Forget that lol i just realized its a pos off set
  10. #40
    Cuppa
    Have you had a look at allied wheels cuppa?
