Results 1 to 10 of 14
Thread: ZD30 upgrades?
    Expert Teamdjbilo's Avatar
    Currently Crabbes Creek NSW
    ZD30 upgrades?
    Hi all
    So have been reading lots and lots on here which is great thought I would throw a post in regards to anything I may have missed!.
    Here goes
    2002 GU patrol zd30 about 290000 on the clock.
    So replaced the intercooler with tig welded one (the other had a leak) and have since blocked the egr also cleaned the MAF sensor(man it was dirty)
    Have seen some definite better performance since doing these 3 things also have a boost controller, boost gauge, egt gauge and oil catch can to come.
    I am going to get a snorkel for it but not sure if I wanna spend the $600 for a safari one and get this installed of go the $145 from eBay for a knock off version and do this myself. I guess because I am afraid of how to rust protect the car after cutting a hole. Also have been told the knock of versions don't do a good job as the safari ones. They don't keep the water out and the joins after about 12 months fail and perish in the sun?
    I have the gear and will be doing an oil change once installed the oil catch can boost controller ect to assure best performance when installed.
    I wouldn't mind hearing anyone's thoughts of anything else that maybe good to do keeping in mind I trying to spend money but need to do something with no job at current (yes spending my redundancy package on my car what could be better?)
    Thanks Simon
    Dec 2012
    Nice, intercooler is a good upgrade, iv spent to much on the car lately,
    I would suggest getting a TJM or ARB snorkel as the cheap and nasty ones are cheap and nasty :P,
    Just wait and shop around I got a great price on mine for a cash deal :P
    Installed it myself, cursed alot but its on and saved me $170 on it being installed.
    Made a massive difference as the stock intake through the guard is rubbish.
    Very lucky, I cant afford not to work anymore, miss having all the time in the world
    Rob,
  3. The Following User Says Thank You to SupRob For This Useful Post:
    Teamdjbilo (20th May 2013)
    X 2 on the snorkel the cheap ones are hit and miss ,Templates are not scaled correctly finish to bodywork hit and miss.
    Not 100% about uv stabilization, Buy a brand name full Aust wide warranty in the event something goes wrong
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    Once you get the catch can on you,ll also notice a big difference
    the motor will run free,er
  7. The Following User Says Thank You to Sir Roofy For This Useful Post:
  8. #5
    Next I'd be fitting an EGT and Boost guage to monitor all your mods.
    You'll need a needle valve from Dependable Distributors in Adel if your fitting
    Full NADs kit.
    A chip an exhaust can see gains of up to 30%, and when its all fitted got get it Dynoed
    New vendor here Rods shop Exhaust when your ready, only heard good reports
    Use nissan touch up paint with brush like nail polish to treat hole for snorkel
  10. #6
    Thanks all. Just spent the last few days jet setting around the country to get work. Before I left tho I did get my egt gauge installed and put my boost garage in all tho the boost gauge is going in the vac part not the psi so I think I have it set up wrong!..
    Will keep looking and work it out.
    Simon
  11. #7
    Yes you have it wrong. Your boost gauge needs to in the boost side, not the vac side. Anywhere after the turbo and before the inlet manifold you can put it. You will need to get a fitting welded in though for the boost. I got two put in on my setup on the first steel pipe just after the intercooler. One for the boost gauge and another for the Dawes valve. In hindsight I could have put in just one port and tee it off but its less likely to break this way.
    Teamdjbilo (30th May 2013)
  13. #8
    Adelaide Hills, SA.
    If you've got heaps of electrical accessories a second earth is a cheap addition to keep everything running at its peak. My cruise control wouldn't work consistently with the air conditioning on before the second earth went on. Wasn't great for the Central Australia trip.
  14. #9
    Where you up to on mods ,like are your EGTs lower now,
    getting a snorkel fitted myself in next few days, I went the TJM
    one. Looking forward to see how it performs. Steer clear of cheap snorkels
    that's all they are cheap and cheap for a reason.
  15. #10
    Blocked egr
    Installed egt
    Installed boost
    Been monitoring this lately to see if I need Dawes ect.
    Max 12psi at any given time.
    About 3-4 hundred temp except when towing a trailer it went to 500 these are not constant figures just the max from what I seen!.
    Still have oil catch can to install and when I do that will do a full oil change and new oil filter!.
