Results 1 to 8 of 8
Thread: Shocks, Air Bags & 2" Lift
Threaded View
  1. #3
    Hey Rossco,
    He s really only talking about a 2" lift and I don't think he needs a mod plate in NSW for that?
    In relation to your part numbers I can't comment but recommend that you talk to your local ARB about the suitability of these part numbers.
    Your air bags will allow you to run a lighter gauge spring in the rear as when towing you can inflate the bags. The weight of your camper does not come into it as its only the ball weight that to should consider. The ball weight will be dealt with by the bags.
    Don't do the caster bushes! Leave the Nissan Rubber bushes in place. No caster correction should be required and its on a car by car basis that this should be decided.
    Maybe a brake bias plate for the rear and you may or may not need sway bar extensions.
    OME all the way mate.
  2. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    AusDave (17th May 2013), DX grunt (16th May 2013)
