Page 4 of 8 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 74
Thread: Rileys GQ
  1. #31
    Expert Frontbumfab's Avatar
    Quarter chop! im about to have a go at it. any special spot it should be cut? illbe welding the bottom plate in too. not the stupid silicon and rivet job.
  2. #32
    22 Post(s)
    Quote Originally Posted by Frontbumfab View Post
    Quarter chop! im about to have a go at it. any special spot it should be cut? illbe welding the bottom plate in too. not the stupid silcon and rivet job.
    just edit the swears mate, then its all good
    96 GQ coil/Cab
    08 G6eT
  3. #33
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Have a search, there's a thread with some good photos. Oh yeah just watch the swearing
    Hello from Under Down Under!
  4. #34
    Got mods on it to delete
    Dont need it nuff said
  5. #35
    1/4 chop is quite easy. If you buy the pre cut ones from eBay then follow there instructions..
    If doing it yourself the cut where ever.. leave about 10mm to form a lip and fold it under before welding.. itll make welding it so much easier..
  6. The Following User Says Thank You to BigRAWesty For This Useful Post:
    Frontbumfab (15th May 2013)
  7. #36
    Yeah sorry about that. Yeah im going to do it myself. Im just not 100% if theres an exact spot to cut. Or fold. Pretty much just under the body line i guess. I wasnt going to worry about folding a lip. Ill just tack the plate on all the way around and grind it back and give it a paint. Bit of silicon on the inside should be sweet
  8. #37
    Idea , get a compressor from a set of red airhorns and set in down via a needle valve of some description .
    drill small hole in side of dizzy and silicon hose in it. Just hit the switch just before water hazzard and pressurize
    Dizzy with small psi and hit the water should keep dizzy water free, There used to be a product out a while back
    that you sprayed all over dizzy Cant recall name but sales guy took top off my dizzy big Accel number on 350 chev
    Threw in cup of water closed it and told me to hit the start button. Blow me down started and never farted once
  10. #38
    Aug 2011
    North West Tas
    56 Post(s)
    Ive seen people set up an airline from a locker compressor to their dissy. They put a restricter so it only runs a constant 2 or 3 PSI which gives the dissy a positive pressure and stops water getting in. Too much mucking around for me, plus i dont have a compressor setup.
  11. The Following User Says Thank You to taslucas For This Useful Post:
  12. #39
    Aug 2011
    North West Tas
    56 Post(s)
  13. #40
    Cheers guys! That dizzy idea is the best. Never would of thought. Might have to try it one day. And cheers for them links. Now looking at it the folded in thing looks really neat. The mudrhino website helps too.
    Also got my gas research throttle bodys on the mail today. Almost paid the full price for a new one looked on fleabay and got 2 s440s and a 90 bend for $150 delivered! Now to order some stainless and plumb everything up.
  14. The Following User Says Thank You to Frontbumfab For This Useful Post:
    BigRAWesty (15th May 2013)
