Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: Dead throttle, f*********k it. GU8 near new.
    Patrol Guru Lonicus's Avatar
    Tewantin QLD
    I have a feeling my TPS may be a bit dodgy as well.
    It's only happened twice so far, but after startup I need to press the accelerator about half way before it registers with the engine and it stays that way until I turn the car off and leave it for 10 minutes or so and fire it back up again then everything is back to normal.
    Car is booked in on thursday to be checked over, I'll mention the death of your TPS to them as they haven't heard of anything like it before either.
    2012 GU8 ST 3.0 CRD. Alloy bull bar, HID spotties, Pioneer GPS/CD/DVD head unit, Beaudesert 2.75" exhaust, Autometer Boost and Pyro gauges.
    WARNING: Towballs used for recoveries can, and do, kill people and damage property.
  2. #22
    Jul 2012
    Hobart Tasmania
    Well let them know here in Tass we have had a few now. LOL. Mine has not done it since. All good so far.
    SHINY AND NEW: 2015 Series 2 Y62 Ti in White. Bone stock, hate to say it but its the wifes car this time.
    OLD SOLD:Silver 50th Anniversary Patrol, 2" Pro-Comp Lift, 32" MT ATZ 4 Rib, 9000lb Warn Winch, UH7700NB + BT UHF Brilliant. Ultra Gauge and some GO FAST bits........
  3. The Following User Says Thank You to WogsRus For This Useful Post:
    Lonicus (14th May 2013)
  4. #23
    Expert Lewy's Avatar
    Nov 2011
    Gatton QLD Australia
    Gee that would suck balls if your out in the middle of the desert on a huge trip and it happens!! Hope you get it sorted..
    GU ST-L 4.2 turbo diesel Because reliability counts!!!!!
    Front Elocker and a Heep more cool stuff :-)
  5. The Following User Says Thank You to Lewy For This Useful Post:
  6. #24
    Tewantin QLD
    Will go and see them tomorrow and relay the info about the Tassie failures Wogs, might see if I can convince them to change it as I don't want to risk getting halfway to QLD and suddenly have no go faster peddle.
    Did you have any early warning signs, like it happening occasionally and then the final failure or did it just give up and die just the once?
    Gotta be Tappy with that!
  7. #25
    Jul 2012
    Hobart Tasmania
    it did occasionally exhibit strange behaviour in that you would push it half way and nothing happened. Then drove home parked it in the drive way and NOTHING no go fast pedal.
  8. #26
    Tewantin QLD
    Thanks mate, that's exactly what's happening to me. As I said only twice so far but with an upcoming drive from Bathurst to Noosa in a couple of weeks I don't want to risk getting half way and getting stranded.
  9. #27
    22 Post(s)
    can someone put up the drawings for the TPS and ECU and how they communicate and what sensors are involved?
    96 GQ coil/Cab
    08 G6eT
  10. #28
    Tewantin QLD
    Just heard back from the dealer, they found the TPS to be faulty and have ordered a replacement.
    If it wasn't for Wogs, and the forum, I probably wouldn't have even gone to the trouble of having it checked out given that it only happened twice. May have saved me from being stuck in the middle of nowhere on my upcoming drive to QLD!
    Cheers guys
  11. #29
    Jul 2012
    Hobart Tasmania
    Your welcome. LOL.
