Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: GU Drivers window goes down by itself!
    Yes its kinda weird. I pull on the door switch to close the window. The window goes up, and when it reaches the top, it goes back down a 1/4 of the way. Dunno if its the switch or what. Everything else works perfect just this. I honestly don't remember this happening before, so it may be normal. You know when you don't realise something has been happening for yonks then all of a sudden your like huh! Never noticed that before.
    22 Post(s)
    Have you taken the door trim off and tried it? Is it just falling back down?
    96 GQ coil/Cab
    08 G6eT
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    My current gu window plays up and the gu i had did the same so its a gu thing
    22 Post(s)
    Quote Originally Posted by roofy View Post
    After it comes Down are you able to put it back into place and it stays?
    96 GQ coil/Cab
    08 G6eT
  5. #5
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Make sure the window is not binding or getting caught on anything as it goes up.
    Lube the window rubbers and runners.
    There is a safety feature for the drivers electric window that will cause the window to stop from going up and come down by about a third if there is an extra amount of load put on the electric window motor.
    I think it's a safety feature for the auto up to prevent kids from getting their hands or head caught in the window.
  6. The Following 3 Users Say Thank You to Yendor For This Useful Post:
    Ben-e-boy (12th May 2013), MudRunnerTD (12th May 2013), P4trol (13th May 2013)
    TRAFALGAR VIC
    35 Post(s)
    its a bit like a yo yo sometimes but I can live with it
    Not falling mate. If I pull the switch half way it will go up and stay up. Its the auto part, when you pull the switch right up.
    That must be it. I did replace my bailey channel on that door and while trying to get the reg out I had to wind it up( I think it was) and the reg wound out too much. So I plugged it in and fixed that. Worked for months after until as of late...
    I had forgotten about that...
    Now just how to work out how to fix it...
    Ben-e-boy (13th May 2013)
  10. #8
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    I'm not sure if there is a relearn procedure or not. I will have a look for you.
    You need to make sure the window is not binding as it goes up.
  11. #9
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    I couldn't find any sort of relearn procedure.
    I would start by removing the door trim, make sure all mounting bolts for motor and runners are tight, give it a lube up and adjust the runners and see if you can get the window to move more freely.
  12. #10
    Nov 2010
    as a windscreen fitter....
    wind window up fully using only manual.....youknow....tweak it up gradually.....
    hold down button fully until window is fully down, continue holding 10 seconds
    pull up on switch until window is up fully, continue holding up for 10 seconds
    should reset upper and lower limits.
    What is happening is callled a pinch reset. It is common when a window is broken OR... force is used to stop a window winding up....such as a fat arm or maybe a baby's head....
    if this very basic reset doesnt help then take it back to the dealer. they can reset or do they're voo-doo magic on it.
    pinch resets can be a pain in the arse and after glass reinstalled, best left to the dealer as it involves the computer.
  13. The Following 4 Users Say Thank You to missingdna For This Useful Post:
    Col.T (9th July 2013), mudski (14th May 2013), my third 256 (14th May 2013), Yendor (13th May 2013)
