Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 43
Thread: Tree Trunk Protector
  1. #31
    Hardcore 04OFF's Avatar
    Brisbane,QLD
    12 Post(s)
    And anyone know why are they called "snatch" blocks anyway ?, you don't snatch with them, ive always thought they should be called winch blocks or winch pulleys ?
  2. #32
    Patrol Guru rottodiver's Avatar
    Nov 2011
    Perth
    I know them as equalising sheaves... But snatch block seems to be a 4wd term for them(slang I guess)
    Scotty
  3. #33
    Legendary NP99's Avatar
    Feb 2013
    Broadford VIC
    Quote Originally Posted by 04OFF View Post
    I could be wrong but I think it's from the old sailing days......
    1999 GU 4500 dual fuel
    Il dado è tratto
  4. The Following User Says Thank You to NP99 For This Useful Post:
    rottodiver (12th May 2013)
  5. #34
    Brisbane,QLD
    12 Post(s)
    Yes i remember the day of the "Tankbulance", and yes the tree was bloody huge !
    Thanks for all the pics and detailed info Scotty, plus info about snatch blocks , one thing though, and i think half the reason behind the OP, is ive never seen a bridle/equaliser strap like yours, but heaps of the ones that look exactly like a tree protector (same width), only noticable difference was the strap colour and label/description on strap.
    Your bridle actually looks a better way to go to be honest, as its smaller/lighter to carry/pack, plus easy to get a hook/shackle over......... so where do i get one ? (lol)
  6. #35
    Expert Tonks's Avatar
    ACT
    Quote Originally Posted by rottodiver View Post
    When you use an equaliser make sure you use a shackle as the "runner" and not just loop it through the end of the strap, the heat caused by the friction can melt either strap while under load.
    Scotty
    Thanks,
    That was another question, is it safe to put a shackle as a runner as stated.
  7. #36
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Thanks Scotty, maybe that post could be put on the safety section or recovery section somewhere? The pics are great
    Hello from Under Down Under!
  8. #37
    Oct 2010
    Old Bar, NSW
    Quote Originally Posted by Great Southern Camping View Post
    Long story short - when it comes to recovery, if you haven't got a heap of experience with it under controlled circumstances, then don't offer advice that could inadvertently get someone in trouble.
    I agree 100% with what you say above, it is not necasarily the way I do it but the level of safety and staying within the equipment specs is the same.
    Agree with the statement quoted above as well.
    My experience came from owning a IFS Hilux, man I got good at recovering myself!!
    I do like to leave some of my gear at home when out with others, BUT take it all if on my own.
    My recovery points are up to the task (well I think so) and have not been into this bridle thing, even though I have used my TTP in some instances.
    All of a sudden about a year ago I noticed the Bridle Kit was promoted somewhere and now it is a must have item, for me I dont agree. It is a good idea but in my case I do it differently and just as safe.
    Out of curiosity how many have a protector for their synthetic whinch rope that is place around the rope and put on abrasive objects where the rope could be damaged?
    MSA used to have one but I cant find it on their site, I have one myself and do use it when necessary.
    Macca
  9. #38
    178 Post(s)
    Quote Originally Posted by Tonks View Post
    Thanks,
    x2, I had assumed that the equalizer strap would just be fed through the loop on the end of a snatch strap (when being snatched obviously) & when doing a double line winch pull that the winch hook would just clip over the equalizer strap? If this is incorrect (& unsafe) I need to get myself a 4th shackle. My thinking was that the additional shackle to connect winch rope to equalizer strap was another potential missile, but hadn't considered friction/heat build up. Can someone clarify please.
    Cuppa
  10. #39
    WA Wheatbelt
    23 Post(s)
    My tree trunk protector
    My bridle
    Showing the width of the tree trunk protector compared to the bridle
    Hope this helps.
    Take care out there.
    Rossco
  11. #40
    I think a few pics of joining straps may be in order, personally I'd never thread it back through the loop.
    You can never get them undone. But answering Op they have different ratings and a different purpose,
    just use it for what its for, If un sure join a club or do an acreditted course, Reasonably affordable $150???
    Again we as Aussie adapt, we have adapted lifting gear to recover in some cases. As for recovery kits Most kits available
    will have all you require, all you do is add extra shackles etc to suit your needs. Plus a frayed strap is usless throw it away
    or cut and get it re stitched for dragging some light logs around camp, not for snatching
