Results 21 to 30 of 43
Thread: Tree Trunk Protector
    Yea that's my thoughts to..
    Owner of
    Westy's Accessories
  2. The Following User Says Thank You to BigRAWesty For This Useful Post:
    rottodiver (12th May 2013)
  3. #22
    Oct 2010
    Old Bar, NSW
    Quote Originally Posted by rottodiver View Post
    Oh and while I am at it for those that struggle with angles, if all sides of a triangle are the same you have 60 degrees ie 2 m between tow points and a 4 meter bridle will give you the 60 degrees..
    Scotty
    Don't you mean 120 degrees at each point of the equalateral triangle
    I'm confusing myself as it is 60 degrees on the "inside"
    Macca
  4. #23
    178 Post(s)
    Beauty, I have two front recovery points, why not use both? Now I don't need to buy two straps.
    If winching off a tree wouldn't you need two?
    Cuppa
  5. #24
    Patrol Guru rottodiver's Avatar
    Nov 2011
    Perth
    Correct me is I am wrong 180 degrees in each triangle... 3 x 60 equals 180 ?
    Scotty
  6. #25
    Cuppa
    No? Why would you?
  7. #26
    Cuppa
    Winch and tree protector. Unless using an extension strap..
    Owner of
    Westy's Accessories
    Nov 2011
    Perth
    Owner of
    Westy's Accessories
    For me though a snatch block for my winch is crucial and then a bridle would be great aswell, I always try to do a 2 fall/line pull as a minimum if possible
    Scotty
  9. #28
    Owner of
    Westy's Accessories
    Thats only one strap...
    If you're happy and you know it tap a post!
    BigRAWesty (13th May 2013)
  11. #29
    Hardcore 04OFF's Avatar
    Brisbane,QLD
    12 Post(s)
    Cuppa
    I think Cuppa is right, if you are using one strap between the 2 hooks on your chassis rails, then back through a snatch block to your winch, then you still need another strap to attach the snatch block to a tree.
  12. #30
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    If you go from the winch to the tree then you only need one strap (used as a tree trunk protector)
    If you were doing a double line pull off a tree and want ed use an equaliser strap bewteen your two front recovery points you'd need two straps. 1 as a trunk protector and 1 as an equaliser
    Hello from Under Down Under!
