Results 1 to 5 of 5
Thread: Battery terminals
    Battery terminals
    Bit of a bug that I see all the time is all the wires from accessories held onto Aux and start batteries with "WING NUTS". Try not to over crowd posts as well. A better option is to use "nyloc" nuts normally 5/16th. A loose connection touring may/has caused fires.Use a nyloc nut and a quick spray of battery terminal stuff.
    Loose wires can be the cause of a myriad of problems, use cable ties where possible and cut these with a knife not plyers as the next person to work on your 4x4 will cut himself on the cable tie end. This goes for the battery tray itself , if they bar holding the battery in place only has Wing nuts Change them as well, cheap as chips
  2. The Following 3 Users Say Thank You to threedogs For This Useful Post:
    04OFF (11th May 2013), FrankW (11th May 2013), Woof (11th May 2013)
    Legendary NP99's Avatar
    Feb 2013
    Broadford VIC
    Or something like this might assist.....
    1999 GU 4500 dual fuel
    Il dado è tratto
  4. The Following 2 Users Say Thank You to NP99 For This Useful Post:
    04OFF (11th May 2013), threedogs (12th May 2013)
    Flush cut side cutters are better than a knife for zipties.
    Sent from my GT-I9300 using Tapatalk 2
    Teno's Troll...
    08 CRD ST. 2" lift, 33' Maxis Bighorns, Snorkel, ARB Deluxe Bar with Foggies, 12000lbs Avenger Mako TDS with Synthetic rope.
    We sell cable tie tools at work that tension it perfectly and cut them off flush.... would be a pain in the rear to use all the time though!
    I have a pair from the aviation industry, They are ok as long as its not to hard to put the cable tie on in the first place,
