Results 1 to 6 of 6
Thread: GQ Patrol how much can you legally lift it ?
    Apr 2013
    Gday guys. Im just wondering if anyone knows what size lift you can legaly put on a GQ patrol in Victoria ? I believe its 2" but ive been told by a few people that it can vary depending on the car. Can anyone help me out ?
    Here you go mate....
    VicRoads' new VSI 8 regulation permits "Owner Certified" 4WD ride height increases up to 75mm, with 50mm maximum allowed for suspension lift, plus a 25mm increase resulting from fitment of a tyre with 50mm greater outside diameter, provided the modifications are undertaken using a commercially available lift kit that has been specially designed and tested for the vehicle application. Under the national guidelines, 'Owner Certified' lifts are limited to 50mm.
    VSI 8 eliminates confusion that previously existed about allowable changes with suspension and / or tyre size. And now 4WD owners do not need to waste time and money on securing an engineering certification to make minor modifications to improve the safety and off road performance of their vehicle.
    VSI 08 also addresses the matter of vehicle modifications where the vehicle is fitted with Electronic Stability Control. Electronic Stability Control (ESC) will be a mandated technology on all vehicles sold in Australia from 2013 onwards.
    A copy of VSI 08 can be downloaded from the link: http://www.vicroads.vic.gov.au/NR/rd...orvehicles.pdf .
    A copy of VSB14 can be downloaded from the link: http://www.infrastructure.gov.au/roa.../vsb_ncop.aspx
  3. The Following User Says Thank You to AB For This Useful Post:
    MudRunnerTD (27th April 2013)
    I wouldn't go anymore than 2-3" I have a 5" lifted ute and I'm looking at lowering it.
    Expert Lieney's Avatar
    Adelaide,SA
    pm your email•
    I have detailed feedback from when I was there.
    Basically 2" without engineer including all types of lift- tyres, body + suspension.
    I tried 3"+35" tyres. Engineer's in Vic wanted nothing to do with 35" tyres.
    06 GU IV Nissan Patrol wagon 3.0L, Tough Dog 2" lift, Xrox bar, 12k Mako winch, 33" muddies, 3" exhaust, Awning, UHF, drawers & fridge, custom sliders, DVDs, custom water tank and pump, rack etc etc.
    Now just in - GQ Shorty 4.2 petrol, UHF - but looking at turbo or V8 conversion
    Brisbane
    ive gone 2 inch on my Gq .wouldnt go any higher
    Oct 2011
    Essendon
    I have a 2 inch GU lift in my GQ and am running 33 inch tyres.
    I would consider 35's and a 3 inch lift but would get it done through a shop like Bidders in Cranbourne because they'll do the engineering certification at the same time.
    That sort of lift doesn't suit me though as I'm building it into a long range tourer at the mo.
    Tip tip tip......tap tap tap....
