Page 2 of 11 FirstFirst 1234 ... LastLast
Results 11 to 20 of 107
Thread: 12V stove
    176 Post(s)
    Doesn't use as much juice as you'd think, the element is very small, has a 15A fuse in it,
    Yep I read that in the specs. Pulling 10 amps is plenty to cause a fire if the wires supplying the cig lighter are too light. It is not reasonable to assume that if a cig lighter is rated at up to 10 amps that the wires supplying it are. It is also a bit suss that a 15 amp fuse is supplied for use with cig lighters rated for 10 amps. The fact that the supplied cable gets pretty warm is also not an indicator of a quality appliance. Still it's your car & your decision about what you choose to do mate. I still suggest that at the very least that you ensure the supply wires to the cig plug are as heavy as those you intend to upgrade the appliance cable to, & that you check the current rating of your particular cig lighter socket. The advantage of spending a few more dollars on quality Hella type socket & plug is that they have more contact surface & a more secure connection, making it less likely to overheat because of resistance from a poor connection.
    Cuppa
  2. #12
    .......... TPC's Avatar
    63 Post(s)
    Cuppa
    Agree with you Cuppa, through my work I have seen what happens when under rated plugs and wiring are used for high current devices, and 10 amps is high current for a car appliance.
    I am thinking of buying one of these myself but will change the wiring and use an Anderson plug, will also only use it on aux battery when not running.
  3. #13
    Legendary NP99's Avatar
    Feb 2013
    Broadford VIC
    Quote Originally Posted by The Dogman View Post
    Nearly half price.....same item......there is always a hefty markup on gear
    1999 GU 4500 dual fuel
    Il dado è tratto
  4. #14
    Cuppa
    I've got 2 cig sockets under the seat with 6mm cable running to them so I'll be right there
    If you're happy and you know it tap a post!
  5. #15
    Agree with cuppa too. As a safety precaution I wouldn't use it on the standard cig plug on the dash.
    Whoever gets one of these though can they give us a report back...lol
  6. #16
    Expert twase's Avatar
    Campbelltown NSW
    FYI, if you have heating on the leads then you have significant power (IR) loss in the leads, upgrading them to a larger csa will result in the device drawing even more power from your lighter socket. Although the result might be hotter pies quicker I would suggest measuring the current draw after the lead upgrade to make sure you are not overloading your vehicles wiring.
    1990 Ford Maverick LWB - BA XR6T powered.
  7. #17
    Patrol Freak kevin07's Avatar
    georges hall
    well being a coeliac ( gluten intolerance) im up for one as i have to take food with me most of the time
    13 y62 the beast that burbles
  8. #18
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Looks good Winnie. Can you adjust the temperature?
  9. #19
    Hardcore healy's Avatar
    south east melbourne victoria
    Nothing better than a travel buddy think I bought one last year at the 4x4 show for $150
    IF ITS NOT BROKEN IT MUST BE A PATROL
  10. #20
    Nope no adjustment
