Page 140 of 1057 FirstFirst ... 138139140141142 ... LastLast
Results 1,391 to 1,400 of 10566
  1. #1391
    Patrol God Bob's Avatar
    Oct 2010
    Pakenham
    47 Post(s)
    Quote Originally Posted by Bob View Post
    Just had a comprehensive Report done by Pedders on the Patrol and booked it in next Tuesday for :-
    1. Control Arm Bushes
    2. Radius Rod Bushes
    3. Drag Link Replacement
    4. Sway Bar Bushes
    5. Steering Damper Replacement
    6. Brake Fluid Flush & Replacement
    7. Rear Sway Bar Bushes
    8. Sway Bar Ball Joint
    Wheel Alignment
    Total Cost $1,666
    Cant complain as the old girl has done 300,000K's
    Picked up the patrol from having the above work carried out.
    Wow just like driving a brand new patrol. Very happy
    sent from galaxy s3 using tapatalk
  2. The Following 2 Users Say Thank You to Bob For This Useful Post:
    Stropp (24th April 2013), Woof (24th April 2013)
  3. #1392
    Expert meh's Avatar
    Nov 2012
    Regents Park, QLD
    Put on my Troll sticker and I Root license plates
  4. #1393
    Perth WA
    63 Post(s)
    New number 3 injector pipe, trying to stop the fuel leaks that are coming from number 1 & 3, all good so far........will just have to see how it goes, could be up for new injectors if this does not stop the leak
  5. #1394
    Expert Lewy's Avatar
    Nov 2011
    Gatton QLD Australia
    Well a few weeks ago I swapped a disco for a outback rear bar.. So here is is all installed couldn't be happier with it!!
    Lewy
    GU ST-L 4.2 turbo diesel Because reliability counts!!!!!
    Front Elocker and a Heep more cool stuff :-)
  6. #1395
    Expert Cbates's Avatar
    Lilydale
    Put strip lighting in the barn door ImageUploadedByTapatalk1366867406.810604.jpg
  7. #1396
    Jan 2013
    Turn off the gas tank to try and isolate whats pressurising my cooling system when the vehicle is cold.
  8. #1397
    Patrol Freak Parksy's Avatar
    Jan 2013
    Nowra NSW
    5 Post(s)
    Installed fuel tank, new high tensile bolts for it as well as rear bar, lots of anti seize. Sprayed the inside of the rear chassis section with lanolin as well as the rear body. Was told it turns to a waxy substance within 3 days that won't wash off so will be leaving the car in the garage until it dries.
  9. #1398
    Jan 2013
    Nowra NSW
    5 Post(s)
    Ordered a complete exhaust for the patrol, extractors, high flow cat, flowing through mandrel bent 2.5" tubes.
  10. #1399
    Perth WA
    63 Post(s)
    First coat of paint on my sliders after sand blasting.
    BEFORE
    [IMG][/IMG]
    AFTER
    [IMG][/IMG]
  11. The Following User Says Thank You to Woof For This Useful Post:
    DX grunt (27th April 2013)
  12. #1400
    Wow they had seen better days hey! Nice job.
