Results 1 to 8 of 8
Thread: maf sensor
    Advanced Stokezi's Avatar
    Newcastle
    maf sensor
    Hi has anyone used a universal maf sensor.If so have there been any problems with them on zd30 gu3
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    If you want your truck to last i suggest that you use oe parts
    not saying the maf your asking about isnt any good but its best
    to stick with the original as its pre set for the z3o
  3. The Following User Says Thank You to Sir Roofy For This Useful Post:
    Stokezi (24th April 2013)
    Jan 2013
    South West UK
    recently fitted a new guts to my Maf sensor oe part - bought on ebay UK - £39.00 sterling - what a difference - everything now runs like a dream and the old truck is pulling up hill & dale like new
    Newcastle
    just wondering would a universal maf cause my truck to blow black smoke, l have now ordered a new one
    TRAFALGAR VIC
    35 Post(s)
    Quote Originally Posted by stokezi View Post
    im not sure of that sounds like it maybe causeing it to over fuel or could be a number of things
    causeing it
  7. The Following User Says Thank You to Sir Roofy For This Useful Post:
    Stokezi (25th April 2013)
    Over fueling or loose hose may cause black smoke plus high EGTs
    @Patroljock52 More details please sounds interesting
  10. #7
    Legendary happygu's Avatar
    Stokezi,
    If you are replacing an old MAF with a new genuine one, i would say go for it.
    If you are trying to find a cheaper replacement, I would be hesitant to advise you that it was a good idea........
    I think that faulty MAFs have been the cause of quite a few failures along with Glowplug Tips
    Mic
  11. The Following User Says Thank You to happygu For This Useful Post:
  12. #8
    Jan 2013
    South West UK
    Hi threedogs - I run two Patrols - one LWB & one SWB both ZD30 engines - have had many interesting challenges with both - mostly to do with performance - LWB 2001, SWB 2003 - there are subtle differences between both engines which even the local Nissan nurds Dealership 'computer says no' so called mechanics don't even know - my LWB has for two years had a performance problem especially when towing heavy loads - power drop off uphill between 2nd & 3rd, engine management light always coming on - changed all vac hoses and many other silly parts while always thinking it was a vac problem and turbo not getting the message and of course the age old question should I block the EGR - have had this mother off three times for cleaning etc and still no difference - reading one of the many forums I thought the MAF change is worth a try - Nissan dealer wanted £130 sterling for a new sensor - research on ebay UK produced a guy who supplies the guts for most MAF sensors - simple, 2 cross head screws to remove old sensor - slot new one in and reconnect terminals - BINGO - my truck now runs like new with no problems whatsoever - any other info I will gladly supply as over the last 5 years I have dismantled and rebuilt most of the running gear, brake systems etc etc - all the best Patroljock
  13. The Following User Says Thank You to patroljock52 For This Useful Post:
    Stokezi (26th April 2013)
