Results 21 to 30 of 33
Thread: Push starting an auto
    Patrol Guru rottodiver's Avatar
    Nov 2011
    Perth
    A small battery that plugs into cigarette lighter when you battery is flat and after 5 mins(on memory) it has put enough power into the battery to start the car
    Scotty
  2. #22
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Or a jumper pack.
    Or jumper leads and a mate.
    But that wasn't the question.
    Ps, the only time my jumper pack isn't in the patrol is when it's re-charging.
    They are great devices:-)
    FanTapstic!
    Hello from Under Down Under!
  3. #23
    Legendary NP99's Avatar
    Feb 2013
    Broadford VIC
    Or a jumper pack.
    FanTapstic!
    Better still, recharge it while driving.....
  4. #24
    Advanced senility Brisat's Avatar
    Dec 2012
    Dakabin QLD
    towing your jigger too far will bugger the linings on the drive plates in the box and will not start your car
    as the oil pump is not working then there is no gears. pull up on a slight downhill, turn the engine and let it roll down the hill and you will see what happens.
    The mind is still making contracts that the wallet can't afford
    1993 Maverick TD 42 mit einem Turbolader, triple battery setup with 2 twin battery units & solar panel, 21/2 & 3 in exhaust, 5 dash mounted gauges, 55 ltr beier frig/freezer, broken winch, UHF & HF radios hf auto antenna, rooftop tent, portable satellite tv system and the ship hanging on the back [4.2 m runabout with 50 johnson] happy hour
    Dakabin 4503 QLD
    WARNING: Towballs used for recoveries,can and do kill people and damage property and also scare the shit out of people standing next to the car
  5. #25
    Thomastown, Melbourne
    6 Post(s)
    Conflicting stories when you do a search but it seems the early autos with the Power Glide transmission seem to work as there is a pump before the trans??
    Only looked into it quickly but it seems it can work but with only some types??
  6. #26
    Aug 2011
    North West Tas
    56 Post(s)
    Quote Originally Posted by NP99 View Post
    It takes a long time to recharge them from 12v. If it's dead flat your looking at 10 plus hours to charge off 12v.
    FanTapstic!
  7. #27
    Aug 2011
    North West Tas
    56 Post(s)
    That may make sense as to why it's an old rumour. Maybe it could have been done back in the day....
    FanTapstic!
  8. #28
    Expert twase's Avatar
    Campbelltown NSW
    Auto's work using hydraulic pressure to actuate the friction plates. The pressure is derived from a pump generally mounted on the input shaft directly after the torque converter. Without the motor running you will not have pressure to activate any drive plates. Some early transmissions such as torqueflite had two pumps, one at the front and one at the rear so in theory you could roll start them.
    1990 Ford Maverick LWB - BA XR6T powered.
  9. The Following User Says Thank You to twase For This Useful Post:
    rottodiver (7th April 2013)
  10. #29
    Expert Bulbous's Avatar
    Apr 2011
    Dubai
    I can't see how this is going to work for an auto, hell, it doesn't always work for a manual.
    I had a flat battery in my 4.8 (Manual) and even towing it at 40KPH failed to start it.
    Seems the fuel pump needs power (probably quite a lot of power considering the amount of fuel it shifts) and if the battery is dead flat then it's just not possible to supply enough to power the pump and start the engine.
    In the end I swapped the battery from the running car into mine - started it up and then while it's running swapped the batteries back. Drove straight to the battery shop then.
    Next time Nissan tell me my battery is weak I promise to pay attention - they quoted 2/3 of the price I ended up paying.
    Steve
    2011 Patrol Safari 4.8 (Fitek)
  11. #30
    Mar 2013
    The received wisdom around here is that you never try to push start an auto (or tiptronic for that matter) it just doesn't work. We did try push starting a tractor once (I was very young) and destroyed the starter and transmission.
