Results 1 to 8 of 8
Thread: Noisy Snorkel
    Mar 2013
    Noisy Snorkel
    Hi Guys, my 2005 3.0 Patrol is making a rumble through the Snorkel(factory Nissan one). It's kind of like a resonating burble at idle and you can still hear it whilst driving! Any Ideas?
    How's the serenity boots's Avatar
    Sep 2011
    Do you have a catch can fitted ? may have a fair bit of blowby . how many kays ?
    Sep 2011
    http://www.nissanpatrol.com.au/forum...ption-achieved. = Wonder if this is related to it ?
    Mar 2013
    No, no catch can fitted and not quite 120000k's. Fuel efficiency seems right and car running quite well!
  5. #5
    Check that snorkel is firm try placing rubber or foam between throat and body.
    I think from memory they vibrate from sucking air not 100% but have heard
    some are very noisey, it can be fixed though Tried a search???
    While its idling try moving it to see if noise changes
  6. The Following User Says Thank You to threedogs For This Useful Post:
    ptcb (4th April 2013)
    Expert janderson's Avatar
    Bearii Vic
    Have asked this before. Have simular noise. Had ARB listen to it, they seem to think it’s normal.
    http://www.nissanpatrol.com.au/forum...om-the-snorkel
    1st G60 Then MQ Now GU
  8. The Following User Says Thank You to janderson For This Useful Post:
    Patrol Guru Drew's Avatar
    Western burbs of Melbourne
    I find you get a bit of a rumble not as much when you do some engine braking
    When I had the D22 Navara with the ZD30 there was a little blow back so there wasn't suction 100% of the time. ARB said it was normal so dunno if its the same kind of thing.
    Expect it to be a little noisier than without one.
    “The best way to cheer yourself is to cheer somebody else up.” - Albert Einstein
    2008 GU 3.0 CRD Auto - Life's too short to eat bad food.
  10. #8
    Mar 2013
    I had a look through your forum record Janderson and that is what it seems to be doing with mine. Will get the tools out and check under the guard as I have already checked the obvious.
  11. The Following User Says Thank You to ptcb For This Useful Post:
    janderson (4th April 2013)
