I have a dual fuel 4.5 that has an exhaust leak between the exhaust manifold and pipe. Tried a couple of auto stores and the gasket is not listed. Have not tried Nissan yet. Anyone else had problems with this gasket or leaking?
Cheers.
Cheers.
i would go to a exhaust repairer as they know these things more than someone punching things into a computer. cheers and good luck!
2008 GU 2" LIFT, GME UHF BLACK KING WHEELS, SAFARI SNORKEL, LIGHTFORCE 240' KAYMAR DUAL WHEEL CARRIER STEINBAUER POWER, beaudesert 2 3/4 system, runva 11,000 comp winch.....
Bloodyaussie (9th May 2013), NP99 (28th March 2013), threedogs (9th May 2013)
What did you end up doing? I have a 4.2, not a 4.5, but I'm having the same issue at the moment. Old gasket was in a few pieces so I taped it together so I had something to show.
Auto store is ringing around for me but no luck yet. Exhaust shop? Nissan?
Standard item mate... I have not had a problem with those parts at all....????
Talk to Garry at Nizbits, he'll have one.
Cheers, the ferret.
stuff gets mighty hot with gas
Yes, I got 2 and sent one to another member on this forum. Exhaust shops have them, can't get them retail as per the usual suspects!
1999 GU 4500 dual fuel
Il dado è tratto
soulburner2000 (10th May 2013)
