Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 58
Thread: A Guide on installing your own remote central locking in under 20 minutes
    Advanced cossy's Avatar
    Brisbane
    Just picked one up JBs this weekend $69.00 will have a go Will try to add photos thanks mudski
  2. The Following User Says Thank You to cossy For This Useful Post:
    Bloodyaussie (18th March 2013)
  3. #12
    Dec 2012
    Interesting thread!!!! I await patiently for more info..... :-)
  4. #13
    475 Post(s)
    Re: A Guide on installing your own remote central locking in under 20 minutes
    What info do you need mate?
    I tapped that app...
  5. #14
    Brisbane
    Ok Its all done will add photos soon. Thanks mudski works fine. question did you remove the old plug?
  6. #15
    Advanced rodneyb81's Avatar
    Brisbane
    Looking for a little assistance I thought I followed all the instructions but it not working so I am scratching my head....
    This is a warlock kg800
    Photos for alarm and my wiring as it is currently...ImageUploadedByTapatalk1370151658.238975.jpgImageUploadedByTapatalk1370151688.939214.jpgImageUploadedByTapatalk1370151724.674306.jpg
    Any assistance would be appreciated
    Rodney
  7. #16
    475 Post(s)
    Hmm, same but different to the KG400 model I have. Have you tried the other trigger wires for the lock/unlock? By memory there is positive and negative activation wires to chose from in the Warlock kit. You may have the wrong set of trigger wires???
  8. #17
    Expert meh's Avatar
    Nov 2012
    Regents Park, QLD
    I know this is an old thread but wanted to say thanks to mudski and just add something extra.
    I installed my alarm/central locking yesterday and on the same clip as described above I needed to wire in the 12v ignition accessory and dome lighting to stop the auto lock after 30 seconds if a door wasnt opened or car started.
    The small plain blue wire is the 12v accessory and the red with black stripe is the door light switch wire (which is negatively switched).
    I was unlucky enough to not have an actuator in the drivers door so had to wire one in and set it up as (+/-)
    Happy to answer any other questions people have with installation of an alarm
  9. #18
    Jun 2013
    Wishart Brisbane
    Thanks to everyone that's made a contribution here. First post, so be kind please. I've run into a bit of an issue with the keyless remotes too, and in searching the web found this thread. I bought a Warlock KG-400 ($78.00 at JB HiFi), and I'm now doing the wiring. The keyless remote module was pretty easy to find with your instructions. Under the dash above the glove box. Remove the glove box and it's pretty easy to see. (IMG_1250). I found the wiring block, and the wiring codes match what was explained on here. The trouble is we're multiple choice on the Warlock side (IMG_002a). From what I can work out, the wiring is:
    Patrol Indicator output : Green/ Red = Warlock brown
    Patrol Indicator output : Green / Yellow = Warlock brown (there are two browns)
    Patrol 12V feed : White / Red (Thicker wire than the others) = Warlock Red
    Patrol Door Lock output : Light Blue (Thicker wire than the others) = Warlock (Multiple choice)
    Patrol Door Unlock output : Light Blue / Red (Thicker wire than the others) = Warlock (Multiple choice)
    I'll earth the Warlock Black to be sure
    So the questions are:
    Do we take the Patrol indicator outputs to each of the Warlock browns?
    How do we wire the multiple choices?
    Thanks in advance
    Mark
  10. #19
    Expert meh's Avatar
    Nov 2012
    Regents Park, QLD
    Hi Mark
    Doesnt matter which brown goes to which as you will have all indicators going at the same time anyway so one brown to each indicator wire
    With your door unlocks you will need positive triggers so your wiring should be
    Orange&orange/black not connected
    Yellow&yellow/black connect to 12V+
    White Lock connect to Thick blue
    White/black unlock connect to thick blue/red
  11. The Following User Says Thank You to meh For This Useful Post:
    Markwr400426 (23rd June 2013)
  12. #20
    Jun 2013
    Wishart Brisbane
    Thank you very much, I'll wire it now.
    Mark
