Results 1 to 10 of 18
Thread: Gasmaster Butane Double Burner BBQ
Threaded View
  1. #5
    178 Post(s)
    I know that plenty of folks have used those butane stoves for ages without problem.......... But........ During our travels around Oz I heard of several first hand instances where folks had been using them & they blew up, luckily with only minor injuries, singed hair & the like. One person had their vehicle saved by a quick thinking neighbours with a fire extinguisher. The main problem is that folk tend to put to large pots or frypans onto them, which partially sit over the top of the canister compartment.
    However I removed the one I had fitted to an external drop down door on the side of our bus after the seal between the canister & the stove became leaky. First I knew was when I lit the stove the flames weren't where they were supposed to be. I reckon I was pretty lucky it wasn't worse.
    I had a heap of (brand name) canisters left over, & more recently bought a blowtorch attachment for them to solder up some Andersen plugs. New canister worked just fine for the first few I did, but then started leaking. I could see the vapour escaping. If I hadn't been on the ball it could have been pretty nasty.
    As a result I've now given up on any appliances which use those canisters, I just don't trust them any more. When using yours please don't get complacent with them. Check EVERY time you use them to ensure you have no leaks.
    Cuppa
  2. The Following 3 Users Say Thank You to Cuppa For This Useful Post:
    NP99 (16th March 2013), Stropp (16th March 2013), TPC (16th March 2013)
