Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: GU8 Nissan patrol Steering wheel audio controls with Eclipse unit on a ST. IT WORKS
    Jul 2012
    Hobart Tasmania
    Hi Guys
    I have a 2012 GU8 50th Anniversary fitted with an Eclipse Audio unit.
    The thing thing that shitted me was lack of audio controls on the wheel. Now MR Nissan wants $180 for the buttons. So before i fork out a huge load of cash, i took the rear cover of the steering wheel exposing the connector to the column, tested the relevant pins with an earth signal and hay presto, the unit responded, changing station, channel ect depending on pin connections.
    SO i tracked down new steering wheel controls for a mear $60 from the USA, its the same as a 2001-2003 Nissan Maxima ones.
    All i need is the wiring harness o connect it all up for $30 and yeah, audio controls.
    SO to all with an Eclipse unit fitted, you can get the unit to have audio fitted controls easy.
    Last edited by NissanGQ4.2; 8th February 2013 at 03:47 PM. Reason: Checking something on Title
    SHINY AND NEW: 2015 Series 2 Y62 Ti in White. Bone stock, hate to say it but its the wifes car this time.
    OLD SOLD:Silver 50th Anniversary Patrol, 2" Pro-Comp Lift, 32" MT ATZ 4 Rib, 9000lb Warn Winch, UH7700NB + BT UHF Brilliant. Ultra Gauge and some GO FAST bits........
  2. The Following 6 Users Say Thank You to WogsRus For This Useful Post:
    awyd (30th May 2015), jack (7th February 2013), Lionel84 (5th November 2013), Lonicus (7th February 2013), lorrieandjas (6th March 2013), NissanGQ4.2 (7th February 2013)
    Hardcore jack's Avatar
    Ballarat Area
    26 Post(s)
    Ripper Wogs, that's great. I felt like I went backwards with some of the controls with the Patrol.
    I'll definitely add it, can you post the links please?
    Jack
    2024 Isuzu MUX
    Jul 2012
    Hobart Tasmania
    Heres the audio controls
    http://www.ebay.com.au/itm/2001-2002...7#ht_500wt_923
    They have gone up since i ordered mine.
    The cable is OEM but i have not got this yet
  5. The Following User Says Thank You to WogsRus For This Useful Post:
    Legendary happygu's Avatar
    Hey Wogs,
    Just giving this a bump, as if this works, I will be doing the same......love your work....
    Mic
    Wogs,
    Just need to divert you from your other Boost Issues, to see if you have finalized the Radio Switches yet and got them working.
    I went in to Nissan and got told that there wont be any wires in the steering column for these same controls, and I cant see it being any differnet to yours even though mine is a 2010 model.
    I am impatiently waiting to see how you go with it, before I pull mine apart.
    Mic
    Jul 2012
    Hobart Tasmania
    Thanks mate, yeah i been a post whore of late.
    The wiring for all of mine is there, on the side of the stearing wheel there is a cover which will expose the clock wire connectors. You can use an earth cable to test for this.
    I have been a little bit too buissy to get on with it, hopefully soon.
    Wogs,
    The one thing that annoys me the most about the Eclipse Unit, is how hard it is to actually turn off when you dont want the radio on, but need to leave the ignition on.
    I am hoping that your controls have or work with an On/Off Button.
    Mic
  10. #8
    Expert Ronin's Avatar
    Brissy
    DO you have pics of the controls ? that ebay link got no pics.
    Edit:
    you can buy the audio harness from Fujitsu Ten, who own the Eclipse brand.
    The item code for wiring harness is: 161140-2170a700
    price is 25$
    http://www.eclipse-web.com/au/
    Customer Service Phone: 1800 211 411
    Service department Phone: +61 (03) 9646 6008
    2012 GU Patrol Simpson Edition. Auto. UHF, Bull Bar, 2" lift with Koni shocks, dobinson coils. 3" stainless Steel Exhaust.
  11. The Following User Says Thank You to Ronin For This Useful Post:
    pas (6th June 2014)
  12. #9
    Jul 2012
    Hobart Tasmania
    I go pics, should be on the ebay link. Will search when home.
    Thanks for the link
  13. #10
    Mar 2013
    Just wonder if there has been anymore progress on this project as I'm interested in this modification
    Sent from my iPad using Tapatalk HD
