Page 6 of 8 FirstFirst ... 45678 LastLast
Results 51 to 60 of 80
Thread: How to fit a Pertronix Electronic Ignition system to your GQ TB42
  1. #51
    Advanced jujunini's Avatar
    Dec 2012
    QLD
    so yesterday i installed my pertronix 1762LS (lobe sensing) electronic ignition system. i reckon this job should take about 10 minutes but the instructions were not very good, and seeing as ive never changed points before i had no idea what to look for when following the very brief instructions. if i had somthing like below i reckon i would have been able to knock it over alot quicker. here is my guide below to assist anyone that wants to do the same and needs help:
    you can see the slits i have made in the rubber
    so there you have it. after doing all that you obviously need to put all the covers back on. i found that the ignitor sat a bit high and pressed slightly on the plastic cover that goes back on first but started the car and let it run then pulled it apart and inspected and there was no damage to speak of.
    as to noticing a difference, the car started with just a touch on the ignition and idled really nice. im yet to take it for a drive as the interior is all stripped out, but it climbs really nicely through the revs when reving at a stop. again, cant mention anything about economy change as i wont be able to drive it for another couple of weeks, but i will keep everyone posted as soon as i am able to start working out that sort of thing.
    if anyone has any questions about that i did, please let me know and if i know the answer ill be glad to help!
    cheers,
    Nic
    Hi !
    Did you change something else like coil ,resistor, ballast, extended rotor or rotor cap, sparks or leads when you installed the pertronix ignitor lobe sensor ?
    have you finally seen the improvment in fuel consumption or power ?
    thx
  2. #52
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Re: How to fit a Pertronix Electronic Ignition system to your GQ TB42
    I'm pretty sure he only fitted the pertronix and left everything else the same. Hopefully Nic will be about to confirm that
    FanTapstic!
    Hello from Under Down Under!
  3. #53
    Dec 2012
    QLD
    Thanks a lot ! And you think it is better to change other parts when installing pertronix ?
  4. #54
    Expert ripper's Avatar
    Leeton NSW
    I think it's better to just do the ignition module to start with. That way if you have issues you know where it's gone wrong.
    1989 GQ LWB Wagon, TB42 Petrol/LPG Auto. Bought Dec 2010
  5. #55
    Dec 2012
    QLD
    It makes sense !
    thank you for the advice.
  6. #56
    hi guys, Lucas is absolutely correct! i left everything else as is in the event the system failed i was still able to go back to the old system! and it hasnt missed a beat and that was over 12 months ago! its great having no more points to constantly adjust!
  7. The Following User Says Thank You to rusty_nail For This Useful Post:
    taslucas (6th February 2013)
  8. #57
    Hi mates,
    I tried hard to understand but I am still confused... I already posted in another thread... Will you please help me with ordering the right one...
    Details are here http://www.nissanpatrol.com.au/forum...l=1#post328130
    Smile
  9. #58
    Aug 2011
    North West Tas
    56 Post(s)
    Quote Originally Posted by Smile View Post
    Hi mates,
    Smile
    Hi smile, I replied to you in the other thread. Hope it helps
    FanTapstic!
  10. The Following User Says Thank You to taslucas For This Useful Post:
    Smile (7th February 2013)
  11. #59
    And what's this 91763-thing???
  12. #60
    Patrol Guru
    Apr 2011
    Melton
    When I installed my 1762ls - I had to pull the dizz as I could not undo one of the screws.
    I noted where the rotar button was pointing before I pulled the dizzy. And when I refitted the dizzy ensured the rotar was pointing in the same direction.
    I already had a GT40r fitted by the PO
