Results 1 to 8 of 8
Thread: Diesel fuel transfer pump
    WA Wheatbelt
    23 Post(s)
    Hello
    I think my diesel fuel transfer pump that transfers fuel from the sub to the mains has packed it in.
    I was driving along, minding my own business and heard a noise. I thought I'd run over something, so I looked in my mirror and saw a big blue puff of smoke.
    Stopped as soon as I could, checked underneath, and all looked good. Checked all the fluid levels and all OK.
    Kept driving and after I filled up the mains and about 20lts in sub tank, noticed that the needle stayed on empty and when I press the sub tank button, the little green light doesn't come on.
    Am I correct? If not, any ideas. Thanks.
    Great start to my beach camping trip!
    Rossco
    WA Wheatbelt
    23 Post(s)
    Bump.
    Anybody?
    Advanced philfree's Avatar
    Oct 2011
    Gympie, QLD
    im not sure exactly what the problem is with why the guage isn't working but the control module for the fuel transfer needs them to work otherwise it can't safely transfer the fuel the the light won't come on the other thing ive done to get them going is reset the module for 30seconds and plug it back in it's located under the radio infront of the gear stick inside the dash for some reason disconnecting the battery dosen't always do the job.
    00, Dx 4.2 turbo, dual batt, 3in exh, Boost contrl, boost and egt guages, GTX2867r, cc intercooler, 3.5in airbox mod, roof console,4 x hid spots and hid projectors, snorkle ,winch,reverse lights and tinted windows, safari tuff clutch, now tuned to 155rwhp also 2000 ford fairmont ghia, 1987 mitsubishi 4wd ute converted to buggy
  4. The Following User Says Thank You to philfree For This Useful Post:
    DX grunt (6th February 2013)
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Did you check the wire harness that goes to the sub tank for any damage?
    WA Wheatbelt
    23 Post(s)
    Not yet, but will do tomorrow.
    Aug 2010
    adelaide
    light wont come on if main is full
    check fuse ?
    OH LEATHER IS NICE
  8. The Following User Says Thank You to my third 256 For This Useful Post:
    DX grunt (7th February 2013)
    SUCH IS LIFE Maxhead's Avatar
    ACT
    I had this issue with my GU8 once Ross, I unplugged the battery for a while and it solved the issue. As above it might be better to reset the module tho. Good luck
    ________________________
    ______ 2017 D-Max _______
  10. The Following User Says Thank You to Maxhead For This Useful Post:
  11. #8
    WA Wheatbelt
    23 Post(s)
    Thanks guys.
    I still don't understand why I would see a puff of smoke. Never-the-less, I'll suss it out. I got a quote from Nizzbits for a new pump. They're not cheap and in fairness to Garry, he gave me some good fault finding advice, too. Thanks, Gaz.
