Page 30 of 196 FirstFirst ... 2829303132 ... LastLast
Results 291 to 300 of 1960
Thread: Anything fishing
  1. #291
    Expert stevogq's Avatar
    behind you
    RE: Anything fishing
    What's your technique for spooling line on your rod? Do you get someone to hold the reel? Or do you use a machine?
    cheers stevo.
    green 1997 rx 2.8td manual, 2"liftkit with poli air in the rear, bullbar, ipf900 spotties, snorkle, uhf, 145lt longrange tank
    soon to include 3" exhaust, custom psi/pyro gauge inbuilt to the dash and plenty natual pinstriping by the bush
  2. #292
    Think its ok with braid as there is no "twist" to it, Correct me if I'm wrong
    Other than that I'd put screwdriver through the spool with some resistance in vice
    and wind away. might be wrong but always worked on mono
  3. The Following User Says Thank You to threedogs For This Useful Post:
    Alitis007 (1st February 2013)
  4. #293
    Legendary Alitis007's Avatar
    15 Post(s)
    Anything fishing
    Quote Originally Posted by stevogq View Post
    cheers stevo.
    I use the vice to pre load the line or i hold it and get some one to reel and i watch how much the rod tapers, but i always cast a freshly spooled reel with just a sinker as far as i can a few times before i use it so the line settles. If the wind isn't in my face i usually settle the first 100 to 150m.
    Braid is good for lures because there is never any slack on the line but your rod needs to have Fuji guides otherwise the braid will cut thru them, you also need to run a mono leader to tie the lures to because the braid doesn't lock onto itself when you tie it in a knot. My soft plastic's rods have 15lb Berkley fireline no stretch no memory braid, but my surf rods have 33lb Shogun no stretch no memory monoImageUploadedByTapatalk 21359699919.767817.jpg
  5. #294
    15 Post(s)
    Anything fishing
    But you cant go too tight or you will birds nest it
  6. #295
    Might have to go surf fishing down Kilcunda this winter Alitis
  8. #296
    15 Post(s)
    Anything fishing
    I've been meaning to go chase some gummies off the surf in venus bay but been flat out!! Kilcunda haven't been there in donkeys years
  9. #297
    My Fore folks foundered that area, my Grandpa built that huge wooden bridge over Burnt Ck too
    Lots of my history down that way,
  11. #298
    15 Post(s)
    Anything fishing
    You can give me the grand tour when we go then!!
  12. #299
    behind you
    Ive been surf fishing only twice believe it or not lol I grew up on freshwater catching carp and trout
    cheers stevo.
  13. #300
    15 Post(s)
    Anything fishing
    My fresh water experience is limited to once at walhala and the rest is at the tambo river for bream and mulloway lol
