Results 11 to 20 of 26
Thread: How I repaired my sill damage (GQ)
    Advanced brw1994's Avatar
    Nov 2012
    Quote Originally Posted by Dales300exc View Post
    I think its more of a cut out and replace job. Ill take a photo haha
    I would have if I ha the access to a mig but I didn't, I also wanted to test myself out as I hadn't done this before
  2. #12
    So you had a half done rivet in ever one of those holes at the same time and just worked them all giving little tugs to each to work the steel out? The benefit is that the holes will be an etch for the bog to hold too. Nice one. I will give that a go on my rear quarter i reckon.
    Cheers MR
  3. #13
    i have been told to tac weld to the panel and pull but i dont have a welder the rivets will work well i think.
  4. #14
    Nov 2012
    Yeh mud that's how they do it in the states, there's a specific tool I saw on YouTube but this is the same principal, all credits too three dogs for this too
  5. #15
    Nov 2012
    And yeh just worked along and went back over, I probably should have done more though, the more you can do with the rivets heaps less work later on
  6. The Following User Says Thank You to brw1994 For This Useful Post:
    MudRunnerTD (31st January 2013)
  7. #16
    Nov 2012
    Well after almost a week of lunch breaks and after work hours it's almost finished and I am quite excited about the results!
    The last run of bog before a sand and paint.
    This is the multipurpose heavy duty bog I used, quite impressive.
    Neat little orbital that helped more than I could ever thank it for, for $109 who can complain?
    After 2x Undercoats and 3x Black Gloss coats before I put some clear coat on tomorrow and the day after
    My checkerplate doors, only finished 1 as I was curious whether NP.com reckons I should use silicone behind it or not.. If I don't get some feedback I'll have to post elsewhere :\
  8. The Following User Says Thank You to brw1994 For This Useful Post:
    AB (4th February 2013)
  9. #17
    Bump to add some pics to this.
  10. #18
    So after seeing this thread I used this technique to sort out rear quarter panel damage. Saw this thread linked today and bumped so I could add some pics. I might do a separate thread too.
    So here is the dent
    ImageUploadedByMotorculture1397476279.698884.jpgImageUploadedByMotorculture1397476824.949902.jpgImageUploadedByMotorculture1397476843.133715.jpg
    Here is the tools I gathered
    Here is the system
    ImageUploadedByMotorculture1397476362.233553.jpgImageUploadedByMotorculture1397476380.799050.jpgImageUploadedByMotorculture1397476397.017879.jpgImageUploadedByMotorculture1397476449.483043.jpg
    Out with the vice grips and slide hammer
    ImageUploadedByMotorculture1397476468.685100.jpgImageUploadedByMotorculture1397476521.617871.jpg
    Patience, reset, red rill,
    ImageUploadedByMotorculture1397476562.101106.jpgImageUploadedByMotorculture1397476577.000359.jpgImageUploadedByMotorculture1397476594.334235.jpgImageUploadedByMotorculture1397476614.100455.jpgImageUploadedByMotorculture1397476629.682761.jpgImageUploadedByMotorculture1397476648.901823.jpgImageUploadedByMotorculture1397476648.901823.jpgImageUploadedByMotorculture1397476685.201782.jpgImageUploadedByMotorculture1397476701.649576.jpgImageUploadedByMotorculture1397476685.201782.jpgImageUploadedByMotorculture1397476736.750460.jpg
    Worked a treat. I laid fiberglass over the panel then bogged and sanded then painted. Came up a treat. Thanks for the idea.
    On a side note! Next trip out I smashed this panel again, it's ok though! I also smashed the other rear quarter and both front quarter panels!!! Happy dayz
  11. The Following 3 Users Say Thank You to MudRunnerTD For This Useful Post:
    Alitis007 (14th April 2014), growler2058 (15th April 2014), mudski (17th April 2014)
  12. #19
    Legendary Alitis007's Avatar
    15 Post(s)
    Instead of making swiss cheese out your quarters you could get a straight tip for the sliding hammer and tack weld it onto the panel and pop it out. If you tact the sliding hammer to the lowest part of the dint you would only need to pull it out a couple of times!
  13. The Following User Says Thank You to Alitis007 For This Useful Post:
  14. #20
    Yes I agree a spot weld would be a winner. This worked very well though for anyone without a welder. A cheap ass pop river kit from Super Cheap is $12 in the bargain bin.
