Results 11 to 20 of 21
Thread: Been advised to Re-torque head and put Genuine H/Gasket
    Legendary 93patrol's Avatar
    Dec 2012
    Bunbury
    That's good so it was just the gasket then
    Just tap it in just tappy tappy tappy
  2. #12
    FIJI
    Fitted Genuine head gasket.....tested head all ok. drove it....still heats goes past 100deg. fitted new thermostat as well. so tmrw will fit a brandnew radiator and see!
  3. #13
    Dec 2012
    Bunbury
    From memory I have seen normal running temp around 104-110 degrees but that was on my motor bike and I could see the actual temp on the dash. Because the cooling is under pressure it can go above normal boiling point. It just when you break that pressure the coolant will instantly boil
  4. #14
    Hardcore the ferret's Avatar
    Sep 2010
    on the coast W.A.
    It might pay to service the radiator too!
    Cheers, the ferret.
  5. #15
    FIJI
    radiator was serviced but showed no improvement. The Radiator shop here have agreed to give the new radiator for testing, if it solves the problem i will have to buy it! if not then they will return it! not bad i guess....
  6. #16
    Re: Been advised to Re-torque head and put Genuine H/Gasket
    With above, pretty sure 100'ish is normal..
    Owner of
    Westy's Accessories
    Patrol thermostats are generally set around the 76 degree mark so 80-90 is normal operating temp.
  8. #18
    FIJI
    Ok....new Radiator went in and the heating problem is solved!!!!!!!!! took it for some hard runs (without coolant, just water) and the factory gauge never went above half mark, the aftermarket gauge went max i think about 95degs...... but drops to abt 80-90degs. I have been advised to use water in radiator rather then coolant!
  9. The Following User Says Thank You to Aben Dean For This Useful Post:
    nissannewby (24th January 2013)
  10. #19
    Seen your patrol in the latest 4wd action to mate. I must say its a very tidy rig and you have it setup quite well.
  11. The Following User Says Thank You to nissannewby For This Useful Post:
    Aben Dean (25th January 2013)
  12. #20
    FIJI
    oh is it there?? in issue 193?? Still dint get my copy yet! Finally i can enjoy viewing it since my heating issue looks like its over! hahaha......
