Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Signs of the bbq jets need replacing?
    So as I do things last moment. My three burner camp bbq ain't working as it should and I need it this weekend.
    Symptoms...
    • put on one outside (right side) burner, fine
    • put the left side burner on and almost straight away the flame will reduce on both burners and then the left side will almost go out.
    I swapped the jets over and it does the same thing but to the right side. Plus both burners do reduce.
    So this tells me its the jets. Yes? This is all running off a full 9kg bottle too.
    Cheers.
    Patrol God Stropp's Avatar
    38 Post(s)
    Check your gas reg, if they sit hooked up to a bottle for a long time the gas will clog it with sulphur, check this first.
    Re: Signs of the bbq jets need replacing?
    X2, and check for kinked hoses
    Owner of
    Westy's Accessories
    Not running a reg. The hose is fairly new...
  5. #5
    38 Post(s)
    Take the hose off the burner and check there is gas of a reasonable pressure coming out of the bottle at the hose end, the hose can collapse internally!
  6. #6
    Patrol Freak lorrieandjas's Avatar
    Brisbane
    Sounds like bung jets on the burner. Which is what you thought.
    Jas
  7. #7
    brisbane
    Yea I'd go jets I always carry a good few spares only takes a little dust/ sand in the lines to stuff them up, even take all the jets off and turn burners on and blow a few burst of gas out to clear the lines
  8. #8
    Take the cast iron burners out to access the brass jet, use one wire off a wire brush to clear.
    As suggested turn on bottle should sound like heaps of gas in bottle.
    Tap, repeat tap cast iron burners as they corrode around holes,
    Flame should be blue with hint of Yellow if at all
    Never had to change a BBQ burner jet in my life. If stuck I can pop over
    I know stuff !!
    Forget all this, the jets only get bigger as they burn out from different fuel stoves.
    can't see it happening on camping gas IMO, PPl don't use stoves enough.
    better off with those $15 jobs x 2 , never let me down yet, cheap as chips if they do.
    Don't buy double unit just a rip off
  9. #9
    Expert stevogq's Avatar
    behind you
    RE: Signs of the bbq jets need replacing?
    Quick answer mark is charcoal can't go wrong i haven't used my 6 burner since I bought it
    Sent from my RM-821_apac_australia_new_zealand_218 using Board Express
    green 1997 rx 2.8td manual, 2"liftkit with poli air in the rear, bullbar, ipf900 spotties, snorkle, uhf, 145lt longrange tank
    soon to include 3" exhaust, custom psi/pyro gauge inbuilt to the dash and plenty natual pinstriping by the bush
  10. #10
    @ TD, The hole in the jets is way smaller than a piece of wire from brush. I tried that...the burners are fine, I will replace the hose just in case....Plus I got one of those little $15 jobbies after seeing Stevo and Trev using theres when we last got together.
    @ Stevo, WTF are you talking about?
    Somethings blocking the supply, as you turn on one burner as the flame is real good and strong, as soon as the other is on, the first burner reduced down and then both are shite.
