Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Thermostat is there or not
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Thanks for the update Alex.
    It will be interesting to see if this also stops your air conditioning from cutting out on hot days now.
    Cheers Rodney
  2. The Following User Says Thank You to Yendor For This Useful Post:
    altech (17th January 2013)
  3. #12
    Expert altech's Avatar
    Nov 2011
    Rupanyup, 3388, VIC
    yes Yendor, as it's going to 39'C today in melborne , pass weeks I have been running the rear air-con and found the air- con really cold than normual , the reason I'm doing this some1 mention about over gassed regards Alex
    Cheers Rodney
    97 GU Ti 4.5 on lpg , uhf icom Pro400, Garmin GPS Maps, HD-Lukas Dash Cam with gps tracking. Snorkel , I-Max 12000lb Winch , Twin rear light bracket on wheel carrier for light & uhf antenna,Draws unit, Electric Cargo barrier, HID headlights kit, LED Light Bar, 2 inch lift with HD King springs and Monroe Gas Magnum TDT 4WD Shock Absorbers, BS Dueler 697 Lt 285/75R-16 .
  4. #13
    Nov 2011
    Rupanyup, 3388, VIC
    Hi Guys , just update air-con worked fine in traffic so all good there , but being a Hot day I ran out of LPG, turn on the petrol and boy did it run like a pig , she stalled about 6 times and wouldn't start ,waited 5 mins then it would start , drove off ,but car was lucking power. pulled in servo ,got some injector cleaner and top up fuel with some hi octan ,50 k's down the road it start to run normal before I got home . ? I started thinking I may have a blocked fuel filter, and on GU 4.5 , where would that be !!! regards Alex
  5. #14
    Patrol Freak lhurley's Avatar
    Oct 2011
    Brisbane. Manly West.
    On the 4.5 the fuel filter is in the engine bay on the drivers side more or less under the battery
    1999 GU DUAL FUEL 4.5 - 2" OME - 33's KM2s - SNORKEL - CUSTOM DINTS.... Goes by the name Candy (the car not me )
  6. The Following User Says Thank You to lhurley For This Useful Post:
    altech (18th January 2013)
  7. #15
    Nov 2011
    Rupanyup, 3388, VIC
    Quote Originally Posted by lhurley View Post
    No it was underbody near transfor case , changed it over and yes it was dirty as regards Alex
  8. #16
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Quote Originally Posted by altech View Post
    Running the rear A/C won't help if the A/C system is over gassed.
    In theory it should make it worse as the condenser has more heat to transfer.
    I still think your A/C cutting out on hot days is/was due to a cooling system fault and the ECU was switching the A/C off because the cooling system temperature was getting too high.
    Possible due to the thermostat being stuck open and allowing coolant to pass to quickly through the radiator, not giving it enough time to cool down the coolant?????..... maybe?
  9. The Following User Says Thank You to Yendor For This Useful Post:
    altech (19th January 2013)
  10. #17
    Nov 2011
    Rupanyup, 3388, VIC
    Hi Yendor, Hot day the other day , didn't cut out, so think must of been the thermostat stuck open , all good thanks Alex
