Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 63
Thread: Supercharging ?
  1. #51
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Can we hear it yet? Lol
    Tap, crackle, pop
    Hello from Under Down Under!
  2. #52
    Been crook hows the build coming along, are you cutting a slot out of bonnet or is all ok
  3. #53
    Expert makeitfit's Avatar
    Aug 2011
    Aberporth beach, west Wales, UK
    Tap, crackle, pop
    Only in my head at the mo lol
    I'm hoping to keep the bonnet without a power bulge
    Mind you there will be a ruddy great scoop on there eventually for the intercooler....................................... .............unless I decide to put the rad in the back and fit a FMIC instead :-)
    Y60 Patrol 4.2 d SWB in puke green
    2" body lift, 2" pedders suspension lift, 35" Simex muds on excel 16" alloys, needs a turbo :/
  4. #54
    Legendary Alitis007's Avatar
    15 Post(s)
    Quote Originally Posted by makeitfit View Post
    Top mount the cooler, the shorter your air system is the less lag you will get
  5. #55
    Aug 2011
    North West Tas
    56 Post(s)
    Isn't lag more associated with turbo's not superchargers? Superchargers being a constant and not having to spool up?
    Tap, crackle, pop
  6. The Following User Says Thank You to taslucas For This Useful Post:
    The BigFella (25th June 2013)
  7. #56
    Aug 2011
    Tap, crackle, pop
    That's what I understood too. Boost from tick over all the way up. Down side ofcourse is heated charge, therefore big intercooler is a good idea. Pretty sure it'll be top mount now anyway. Not prepared to loose the space in the back for the rad just yet .
    While I'm waiting for the bottom pulley to be made I'll be doing a twin fan cooling job on the stock radiator. Then a fan cooled T/M I/C and assorted I/C mounts etc etc :/
  8. #57
    15 Post(s)
    Tap, crackle, pop
    Most chargers sit right over the intake ports of the head/ heads so you wouldn't have any lag, but when you have cooler and piping thats a cavity you need to pressurize. Think of it as a tube, your compressor might have 170psi in its tank but when you squeeze the trigger it takes a minute to start building pressure. I could be wrong i haven't really played with chargers just with turbos and in all my cars i've had them hitting boost at around the factory mark no matter how high its wound.
  9. #58
    Aug 2011
    North West Tas
    56 Post(s)
    Yeah the cavity needs to pressurise but that only happens once at start up. They don't "spool up" like a turbo, they are a constant so my guess would be a couple of seconds to pressurise the piping then constant pressure until engine stops
    Tap, crackle, pop
  10. #59
    15 Post(s)
    Your probably right mate, see when this blokes dose and what feed back he gives hey!
  11. #60
    Expert Pezzer's Avatar
    Jun 2013
    Gold Coast
    How did the build go?
