AWSOME...It worked! Wow, great programe...runs in the background and automatically resizes any photo emailed, uploaded etc. no need to fiddle AND it only changes the copy being sent so you still have the original, unchanged! Very impressed....ANYWAY, on with the guide.
Upon checking my pics, I noticed I have no photo of removing the old lights. It is really easy and can be done in 2min using only the 10mm socket and the large flat screwdriver. I am doing my mates car (possibly) this weekend so I will take some pics then and add them if anyone wants them!
1/ Remove panels behind lights inside cargo area (small narrow one on left and large one on right were
jack is stowed).
2/ Undo both the top and bottom screws with the 10mm socket (on the left there is 3 screws, leave the
middle one alone!)
3/ There are two ball clips securing the outside edges of the lights to the body, so...take your large
flat blade screwdriver and (while protecting your paint work with a rag) insert it in the groove
between the outside, top lip of the old driving light and gently lift. You will fell a clip slip
out, tha'ts good. Repeat the process on the outside, bottom lip also, remembering to support the
light now as it should now easily fall out into your hand!
4/ Undo the plug at the back of the light and remove....THAT'S IT!
Shayne
