Results 1 to 10 of 19
Thread: Maverick\GQ Rock Sliders
    Advanced brw1994's Avatar
    Nov 2012
    Thought I'd take pics and add them for you all. Just what I've been working on at the moment, basically my first real test using an Arc Welder used to MIGs but I'm pleased . Used pre-bent elbows as being 18 I had to buy all my own tools and can't afford a tube bender. All the tube is 50mm Black Pipe 4mm wall.
    What do you guys suggest, 2 or 3 mounts? Is 2 enough/is 3 overkill?
  2. The Following User Says Thank You to brw1994 For This Useful Post:
    AB (9th January 2013)
    3 for sure
    Also i Highly recommend adding Flat Plate to the underside. I also added Checker Plate to the top of mine. Without the flat plate on the bottom the cross braces will pick up BIG sticks and do WAY More damage to your sills that not having them in the first place....Speaking from Experience mate.
    Nice one.
    Cheers MR
    Nov 2012
    3 for sure
    Nice one.
    Cheers MR
    Yeh that might be the go, what thickness?
    Pretty thin mate, just something to deflect the sticks and stuff. maybe 1.0mm or so?? Not sure on available sizes. Same goes for the checker plate. and either fully seal it (i did) or leave the corners open to drain out.
    Good luck
    3 for sure
    Nice one.
    Cheers MR
    Stops sticks getting caught between where you get in....... And where you get out
    Thomastown, Melbourne
    6 Post(s)
    Lovely mate...... satisfying making them yourself, take Darrens advice he knows his stuff mate!!!!!
    Patrol Guru 89gqpatrol4x4's Avatar
    Brassall
    Nice job mate, made mine myself too. nearly identical just used 50 internal diameter pipe. show some pics of them when there on. and how you did it, i.e. weld on clamp with bolts etc. Keep up the good work. I haven't got any plate on the underside of mine and nothing has happend yet, (touch wood) but after reading MR's post am going out to have a look at that right now.
    GQ Snorkle Lockers front n rear
    Jan 2013
    Just a thought, what if you use steel checkerplate just on the top? Im curious. They look the goods! Ill probably make some soon.
  10. #9
    Quote Originally Posted by Dales300exc View Post
    I like the flat panel steel on the bottom so the stick just slide and deflect straight off . just putting checker on the top then each of those cross braces will remain as a decent snag and you will be amazed what a stick the size of your wrist will do coming UP through that at 60kph..I have had a stick that size come up Through my Floor under the front passengers seat while someone was sitting in it!
    My Sills were destroyed over a few years at Each and Every cross brace intersection with a Dent big enough for an Apple to sit.. It took allot of work to fix and i welded the plate on and never had a problem since.
  11. #10
    Jan 2013
    Yeh true valid point!! My sills caved in from a stump
