Results 1 to 10 of 14
Thread: Patrol..
    Expert meh's Avatar
    Nov 2012
    Regents Park, QLD
    Patrol..
    So here she is all washed.
    A couple of questions if you guys wouldnt mind.. How much lift would you say this truck has had ?
    How do I measure ?
    Next question. Do you know what computer/?black box would be doing underneath the truck ?
    Final one - I have four of these in the boot, any idea what they would be used for ?
    WA Wheatbelt
    23 Post(s)
    Nice truck. Congrats.
    The last pic looks like 4 x cargo tie down points.
    Did your truck come with an Owner's Manual? Check it out.
    Take care out there.
    Rossco
    Oct 2011
    Essendon
    Indeed, nice truck!
    I very nearly bought one of these bad boys but went with a GQ instead....
    You could follow the wiring, that will give you a clue to what the black box is.
    As far as the lift goes, not being a GU driver, I'm not sure but it'll looks like about 50mm in the pics.
    Go and find a stock one on the street somewhere measure the tire clearance and compare it to yours....not 100% accurate 'cause old springs sag etc. but it'll give you an idea....if the owner comes out and yells at ya, run! Good exercise! LOL. Also you can poke your head underneath and check what brand of springs and shocks you've got.
    Little black box could be electronic rust protection. Can't help with your suspension but measure from centre of hub to bottom of your wheel arch, post up your measurements and hopefully someone with a stock gu can help
    Don't stroke it, TAP it!!!!.....
  5. #5
    Advanced largey's Avatar
    Oct 2011
    I just checked under my patrol gu dx it has the little box too
    "Livin Large"
    Gu dx Ute
    A.K.A = ABBY
  6. #6
    Patrol God Stropp's Avatar
    38 Post(s)
    The four rings are tie down points and the black box definitely looks like as others have said electronic rust protection, not sure on lift but pics look lie maybe 2"!
  7. #7
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    The little black box is just a plastic cover to protect the body to chassis electrical plugs.
    If you remove the cover you will find 3 connectors behind it.
    In the photo you can see one harness runs up through the floor, (comes through just under the LHF seat) and the other harness runs down to the tail lights etc.
  8. The Following 2 Users Say Thank You to Yendor For This Useful Post:
    largey (8th January 2013), threedogs (16th January 2013)
    Expert PattyWgnOwen's Avatar
    Jun 2011
    Brisbane North
    http://www.patrol4x4.com/forum/nissa...weights-69039/
    Here is a thread I started with links to figure out the manufacturers height of your patrol model
    GU4_3"lift_4"exhaust_sliders_Bars_fridge_roof top camper_lockers_duramax_allison_ohh yeah!!!
  10. #9
    Advanced melcor's Avatar
    Nov 2012
    yeah the black box is just a plug cover ..
  11. #10
    Clean looking 4x4, I'd say 2" lift but may look more if only running 265s
    What size tyres are you running
