Results 1 to 10 of 39
Thread: Rear Air Locker - are they worth having over standard LSD?
Threaded View
  1. #8
    22 Post(s)
    it depends on how hard core you go. an lsd can turn into a poormans rear steer in some situation sometimes that can work in your favour sometimes it wont. on a track i regularly drive there is a section that i wish i had a rear locker because the lsd opens up and drags the front sidways and i get a bead leak every time. there are other tracks i drive where i use this to my advantage
    96 GQ coil/Cab
    08 G6eT
  2. The Following User Says Thank You to Ben-e-boy For This Useful Post:
    GU_Nemesis (3rd January 2013)
