Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
Thread: Rear Air Locker - are they worth having over standard LSD?
    Advanced GU_Nemesis's Avatar
    Hi Guys,
    Just a question in regards to air lockers. I have a 93 GQ TD42 which I am about to get an onboard compressor and front locker fitted to. I have heard that the rear LSD fitted to this truck is very reliable and will get you into and out of most places, so I am just wondering considering the cost and the fact I am doing the front anyway.. Is there any real advantage in having an air locked rear over the standard LSD? I heard that once you install the rear locker it is an open diff and you lose the LSD, requiring the locker to be used more where you would normally be ok with the LSD. I have also been told that with the front locker alone it's all you really need and can avoid extra cost of getting a rear locker if they don't offer any real advantage. What are people's thoughts on this?
    Cheers,
    Scotty
    My opinion is that Patrols don't need rear lockers because the LSD is fantastic
  3. The Following User Says Thank You to Winnie For This Useful Post:
    GU_Nemesis (3rd January 2013)
    Expert Lewy's Avatar
    Nov 2011
    Gatton QLD Australia
    In my GU I also got talked out of putting a locker in the rear. But now wish I had both front and rear!! I like the rear lockers for when traveling down steep descents and one rear side comes out of traction with the ground it allows the 4wd to over run and I don't like that at all so IMO I would get both.. The rear LSD in patrols are bloody good but they do start to let you down when your in the more hard core stuff.. Also I would not ever use ARB lockers again (have had ARB lockers for years in other 4wds) not after buying a Elocker.. They are just so much better in every way!!
    Lewy
    GU ST-L 4.2 turbo diesel Because reliability counts!!!!!
    Front Elocker and a Heep more cool stuff :-)
  5. The Following User Says Thank You to Lewy For This Useful Post:
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Stick with the LSD IMO. They're nearly like a locker anyway
    ________________________
    ______ 2017 D-Max _______
  7. The Following User Says Thank You to Maxhead For This Useful Post:
  8. #5
    From my trip away last weekend, my mate in his cruiser was constantly switching his locker on and off. I got everywhere he did, with a standard lsd. I don't know if I'd bother with a rear locker, mainly because of the awesome lsd.
    Teno's Troll...
    08 CRD ST. 2" lift, 33' Maxis Bighorns, Snorkel, ARB Deluxe Bar with Foggies, 12000lbs Avenger Mako TDS with Synthetic rope.
  9. The Following User Says Thank You to teno45 For This Useful Post:
  10. #6
    Go the front locker only and put the extra cash towards the Turbo Setup you know you want....... For Sure !
  11. The Following User Says Thank You to MudRunnerTD For This Useful Post:
  12. #7
    Haha Thanks MudRunnerTD, yes there is a DTS turbo kit install planned as well!
  13. #8
    22 Post(s)
    it depends on how hard core you go. an lsd can turn into a poormans rear steer in some situation sometimes that can work in your favour sometimes it wont. on a track i regularly drive there is a section that i wish i had a rear locker because the lsd opens up and drags the front sidways and i get a bead leak every time. there are other tracks i drive where i use this to my advantage
    96 GQ coil/Cab
    08 G6eT
  14. The Following User Says Thank You to Ben-e-boy For This Useful Post:
  15. #9
    Jan 2013
    i recommend getting just the front to start with, because unless you are changing ratios you will be up for the same coin if you do it now or later.
    just if you fit locker to the rear now you will never know the virtues of the lsd. and you might find that the lsd suits what you want perfectly.
  16. The Following User Says Thank You to Jacket_1985 For This Useful Post:
  17. #10
    Cheers guys, thanks to you all for your replies. I think I'll just go the front locker for now and put the extra cash towards some other mods.
    Thanks,
    Scotty
