Results 1 to 10 of 15
Thread: 3 wheeled gq
    Nov 2012
    Qld
    3 wheeled gq
    I wanna tell you all a small tale of woe I had 2 days before Christmas.
    I had just moved house with my fiancée and the gq handled the constant loading and reversing driveways like a champion being constantly loaded and unloaded including a trailer.
    As a celebration we took a trip out to glasshouse to have some fun with mates,
    Again the gq with standered 4.2 na diseal and standered lift was a work horse and only 1 shameful event involving a 80seires having to snatch me out.
    A few days later I was called by a mate to help lift a motor so off I went like a true mate, I felt a small vibration doing 110 on the highway and when I was less than a km from his house going around a roundabout the vibration got bad shaking the wheel and peddles, but before I could pull over and check I heard a bang the front left corner of the gq dropped and I had that awkward moment on seeing my from wheel overtake the vehicle.
    Luckily this happend doing very low speeds and not 110 on the highway
    The damage was minimal just the dust guard bent, and left quarter panel probably damaged beyond repair.
    All 6 heel studs had stripped, the mag was surprisingly allright.
    I had to tow it to my mates place ( 100$ for less than a km up a hill and me with 65 bucks on me after paying bond and giving the misses money for food) try to track down new studs at 430 on a Saturday afternoon( parts stores failed me) luckily a mate had a set of gu hubs laying around and gave me the 6 studs and wheel nuts. And like a true mate after I assisted lifting the motor as was the original plan, we spent a few hours in full sun and 30 odd degrees, replacing the buggered studs.
    I would be screwed if it wasn't for fellow 4x4 mates the one with the gu parts I met 3 days prior on a tracks.
    The morals of this story is
    1. Look after your mates one day you WILL need there help ( be generous with you beer and allways pay your debts even I they say no)
    2. Allways check your wheel nuts perticuly after 4x4ing
    3. Have RACQ it's cheap and can get you out if trouble(I learnt the hard way)
    And finaly any noise that sounds new or strange, pull the F over.
    That might not applie for the older more experienced boys but I'm young and this if my first 4x4.
    This has been a big lesson for me and hope this dose not happen to anyone else.
    You can over come anything with speed and commitment
  2. The Following 2 Users Say Thank You to Goochness For This Useful Post:
    macca (29th December 2012), Warnie (31st December 2012)
    Western suburbs of Melbourne
    12 Post(s)
    Very lucky buddy that it wasn't a wheel at 110kph, your safety and the safely of others would be compromised. Could of killed you both.
    Like a unlucky bloke a few months back on the princes hwy near Laverton was changing a blown tyre was killed by a wheel that had come of a motor vehicle about 50 metres down the hwy.
    CHECK YOUR NUTS.
  4. The Following User Says Thank You to MEGOMONSTER For This Useful Post:
    Goochness (24th December 2012)
    Patrol Guru Lonicus's Avatar
    Tewantin QLD
    Nothing to do with age mate, even us old buggers are learning all the time, specially on this forum!
    x2 with Mego, very lucky.
  6. The Following 2 Users Say Thank You to Lonicus For This Useful Post:
    DX grunt (24th December 2012), Goochness (24th December 2012)
  7. #4
    Age has nothing to do with it ,I love learning new "stuff",
    You were lucky, but no injuries so a good out come,
    check air in tyres, check wheel nuts,
  8. The Following User Says Thank You to threedogs For This Useful Post:
  9. #5
    us poms are crap at cricket fracster's Avatar
    North West England.
    You were pretty lucky there mate, as said above, age has nothing to do with, nobody knows everything and we are all learning.
    It is now official, we are not quite so sh@t at cricket as we were! Rugby Union is a different matter.
  10. The Following User Says Thank You to fracster For This Useful Post:
  11. #6
    WA Wheatbelt
    23 Post(s)
    Quote Originally Posted by Lonicus View Post
    x3. I couldn't agree more, Lonicus!
  12. #7
    Nov 2012
    Qld
    I also found there wasn't a lot of threads discribing how to remove the studs, I had a Haynes gq manual and that still didn't give a lot of information, turned out my rotor had seized to the wheel bearing assembly, took a bit of research to figure it out because non of us had pulled the studs off a patrol before. I also found 2 circlip groves on the axel once the manual hub was removed, but it only had 1 clip in it, would this hider the hub locking at all? When I get time I will replace it.
    But anyway it's a good excuse to keep it off the road for a week or 2 to fix the panel and put all the goodies I have like the iron man lift kit, UHF, and start my custom bar work.
    On a side note how many post do I have to do before I stop being a beginner?
  13. #8
    Feb 2011
    Shed
    45 Post(s)
    50 I think but could be 25???
    Tap someone who cares
  14. #9
    Patrol Guru Morton's Avatar
    Sydney West
    bloody hell you sure are one lucky bloke, big hammer for the studs, smack it firm & they will pop out, slide the new ones in, put the wheel & nuts on, tighten up & this is good enough to get it to slide into position, it goes in easy, as for the 2 circlip groves, you only use the one grove, I think the second is for auto hubs or something like that.
    Anyways I would be buying a lottery ticket & a cartoon of beer maybe 2, dont forget a bottle sherry for the girlfriend, just some good sound advice, everytime you buy a stack of bits & pieces for your patrol buy her something ie: $1-$500 = box of chocolates, $501-$1000 = flowers, $1001 - $1500 = Dinner, $1501 - $3000 = Dinner with benefits, anything more than that & u can afford all 4 in 1
    2002 3L GU Patrol, 2" lift, 33's, snorkel, dual battery, sliders, DVD, bluetooth
  15. The Following User Says Thank You to Morton For This Useful Post:
  16. #10
    Sydney West
    [QUOTE=growler2058;309555]50 I think but could be 25???
    25
  17. The Following User Says Thank You to Morton For This Useful Post:
