Results 1 to 10 of 102
Thread: Nissan Fast / E-Fast Software Download
Threaded View
  1. #2
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Nissan Fast Installation
    These instructions should hopefully get the Nissan Fast System up and running for you.
    There are a few steps to installing Nissan Fast, I will do my best to explain, sorry if i get you completely lost, but that's what i get paid 2 do
    Step 1 - Program Installation
    1. In
    Windows Explorer or My Computer locate the AR.zip file you downloaded and extract the file to a Temp location. For this example i will use:
    C:\Temp\
    2. After the file has been extracted locate this directory
    C:\TEMP\AR\FASTPRG\WIN2000\SETUP
    3. Execute the Setup.EXE file
    4. You will be prompted to choose a destination folder
    I will leave this as the default C:\Nissan
    Select Next
    5. You will then be prompted to Start Installation
    Select Next
    6. It will then install, when the Install completes it will come back a prompt “Installation Complete”
    Select Finish
    Step 2 - Check That The Installation Worked
    1. There will now be a short cut placed some where on the windows task-bar, called Nissan Menu
    2. Select the short cut
    Nissan Menu
    This will open the Nissan Fast Menu
    3. Select any of the icons in the menu, it should come up with an
    Error Message
    4. Select
    OK
    5. Select
    Quit
    Step 3 – Copy the Nissan Fast Catalogs
    1. In Windows Explorer or My Computer locate the C:\TEMP\AR directory.
    2. Copy the AR Folder to C:\NISSAN
    Step 4 – Setting The CD ROM Setup
    1. In Windows Explorer or My Computer locate the C:\Nissan directory
    2. Locate the file NFSET.EXE and Execute
    This will bring up the FastSet Nissan Fast for Windows NFSET menu
    3. Select the CD-ROM SETUP TAB
    4. Make sure Drive 1 is highlighted and select Browse, this will open the Browse For Folder window
    5. Locate the C:\Nissan\AR folder and single left mouse click on it
    6. Select OK
    Drive1 should now look like this
    4. Select OK
    Step 5 - Run Nissan Fast
    1. Select the short cut Nissan Menu on the Windows Task Bar
    2. If it asks you to run a file called NFUdate.exe select YES, it will then go through an install procedure before opening the Nissan Fast Menu
    3. Select the Fast System Icon
    This will open the Main Nissan Fast Window
    If you have
    AR 1 showing then you have the Australian Catalog working, now you can sit back and have a few
    *NOTE - Known Issues *
    1. If you run the E-Fast System and get a
    tdbg6.ocx error - you will need to download this file into the C:\Nissan Directory
    2. If running a 64bit operation system, you will have to run it in XP Compatibility mode for E-Fast to work or you will still get a tdbg6.ocx error
  2. The Following 9 Users Say Thank You to NissanGQ4.2 For This Useful Post:
    89GQ (4th February 2012), Dapple (28th February 2012), Dirtydog16 (18th February 2012), Fity (23rd March 2012), harro959 (12th November 2012), im2xtreem (14th August 2018), JoseM (10th June 2013), Robo (6th December 2012), the evil twin (16th January 2011)
