Results 1 to 3 of 3
Thread: fuel guage died!
Threaded View
  1. #2
    To get to the sender unit lift up or remove the carpet in the cargo area. There is a removeable section of floor that will give you access to the top of the fuel tank.
    Remove the sender unit and use a multimeter to check the resistance with the float arm in various positions. If the resistance does vary (I don't have specs at the moment) then the fault is most likely in the gauge.
    Tony
  2. The Following User Says Thank You to YNOT For This Useful Post:
    lotus (14th January 2011)
