Results 1 to 9 of 9
Thread: Advice on Exhausts
    Advanced WilliamPatrol's Avatar
    Townsville
    Lightbulb Advice on Exhausts
    Hey Guys,
    I'm thinking about replacing my exhaust due to the stock muffler having small holes in it.
    I'm chasing the best bang for buck exhaust out there to suit a 2008 GU CRD 3.0L Ute (LEAF SPRING).
    I'm open to all suggestions and advice also from previous installations by others.
    Cheers,
    Will
    2008 GU CAB CHASSIS 3.0L ZD30
    Supercheap Auto Member / Apprentice Mechanic
    ... Now there's a solution!
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Try this: http://www.nissanpatrol.com.au/forum...t-2.75-exhaust
    I think its the best exhaust for a CRD motor around
    ________________________
    ______ 2017 D-Max _______
    X 2 the Beaudesert 2.75" seems to suit the 3lt Cr motor well, PM Keven 07
    he's just fitted one and is very impressed with the performance,price .
    best bang for buck going atm
    Patrol Guru Drew's Avatar
    Western burbs of Melbourne
    x3 just sweet
    2008 GU 3.0 CRD Auto - Life's too short to eat bad food.
  5. #5
    Townsville
    Thanks guys,
    Ill definitely take a look.
    Would you recommend the Scotts Rods exhaust?
    3inch, I know... It's a little overkill on a 3.0L but its cheap. It would be good to hear from someone that has installed it.
    Heres a link:
    eBay Australia: Buy new & used fashion, electronics & home d
    There is also a REDBACK 4x4 exhaust I found:
    However the REDBACK is fitted for a coil spring rear... Is there any difference between the coil and leaf?
  6. #6
    Western suburbs of Melbourne
    12 Post(s)
    I chose the Taipan 3" exhaust for my patrol, as I wanted it to breathe better, without the noise and drone a 3" exhaust makes. The difference is minimal maybe 5dB from standard. And the longer its been on the better its been sounding.
    Never argue with an idiot, cos he'll bring you down to his level, then beat you with experience.
    Pog mo th'oin.
  7. #7
    Patrol Freak kevin07's Avatar
    georges hall
    Quote Originally Posted by WilliamPatrol View Post
    Hey Guys,
    Cheers,
    Will
    will after doing a lot of research just as your doing the overall the best to fit was the beudesert 2.75 as they have done a lot of research developing this exhaust for our motors i dont believe others have done this research.after checking other companies products some saying you cant buy 2.75 zorsts and you have to have a 3". they dont tell you that the 3" may cause overboost problems .some have taken their 3" off as it caused so many problems you can fix all them problems with a lot of coin for power modules etc or get a researched exhaust that costs a bit more but ill guarantee will blow your mind that it can increase your power that much.BEUDESERT 2.75" AS YOUR CHASING BEST BANG FOR YOUR BUCK.kev
    13 y62 the beast that burbles
  8. #8
    Townsville
    Exclamation
    Quote Originally Posted by kevin07 View Post
    Thanks Kevin07,
    But I don't think they make an exhaust for the 2008 go ute (leaf spring), only coil....
    Keep opinions coming.
  9. #9
    georges hall
    Thanks Kevin07,
    Will give em a call im sure they can bend something up for the tail pipe
