Results 21 to 30 of 45
Thread: Tubular winch bumper, home build.
    Expert makeitfit's Avatar
    Aug 2011
    Aberporth beach, west Wales, UK
    Aye. Winch should be here Monday, then I can do the final holes for the base and fairlead. Then it's off to the galvanizer
    Y60 Patrol 4.2 d SWB in puke green
    2" body lift, 2" pedders suspension lift, 35" Simex muds on excel 16" alloys, needs a turbo :/
  2. #22
    Aug 2011
    Final fit
    Been a while but stuff happened
    Any road up had a day of light spannering today and only one hour of rain, result :
    One winch tray bolted an fitted in final position. I had to rotate the gearbox one bolt hole to get the clutch lever to work without cutting the truck
    Smiley tubes and lower struts in too
    What overhang my approach angle is better than it was with the stock bumper
    Here you can just see the rear strut too. This will help stop the bar moving backwards if I hit a tree again ! Bit over exposed
    Not as pretty as you guys can do for sure but then 180 of your dollars is all it's cost me
    Wiring and testing next then off again for powder coating
  3. #23
    Aug 2011
    Got round to wiring up the winch at last today Several hours in a row with no rain
    Oiked out the old air box ( now redundant with the snorkel) to make a luverly spot for the solenoid
    Had a little rearranging to do in order to get the solenoid high enough . Lengthened all the cables from the winch and heat sealed the ends up All ends greased up now too
    Off to test tomorrow, should find some landies stuck in the mud somewhere lol
  4. #24
    Legendary happygu's Avatar
    Love your work, as you will have awesome approach angle.......but i'm not sure the bar is gonna help if you hit a tree, as your side arms won't take much to bend in. I would look at gussets for extra strength.
    Just keep it out of the trees and no-one will be able to stop you.
  5. #25
    Coming along nicely, instead of GAL have you looked at zinc plating, looks same , but may be cheaper price wise.
    great approach angle mate, well done
    Don't think the cord holding the battery in went un noticed either, make a poper bracket eh
  6. #26
    Aug 2011
    Ha ha that was a bit of bailer twine only a few weeks back lol Bracket on the way ................................... next week
  7. #27
    Dec 2012
    looks good champ
  8. #28
    Aug 2011
    Cheers mate, just gotta get round to finishing it now lol. Maybe after crimbo
  9. #29
    Aug 2011
    A little update for you guys. I got round to the final fit (for now)
    Didn't get it zinced yet as I'm doing one for the back too and so will do them both at the same time.
    So in the mean time I etch primed it and sprayed it with Hamerite metal look paint. pretty tough for the short term
    It seems to have survived our recent snow drift challenge
  10. #30
    Looking good Buddy, funny what a coat of paint will do,
    you can get plastic plugs for the end of the bar.
    My BFF needed them for aircraft industry, ended up
    that Hayman-Reese a towbar company made them.
    Or you could get a piece of polyblock turned up.???
