G`day Corski
I think that you may have a broken pressure plate diaphragm.The diaphragm gets a crack ini between the fingers and as the crack widens with every depression of the pedal the clutch gets lighter and lighter and dosen`t lift the plate high enough to release correctly.Also the clutch will more often than not will slip.Also check the fork and pivot as the forks do crack.
