Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Limited slip diff question
    Hi,
    My limo has seemed a bit sus the last few times we have been out for a fourby,when I had it up on the hoist giving it a clean my mate held one of the rear wheels and I could spin the other one with not a huge amount of force,it was a little bit harder at first but once it started spinning it spun quite freely,to me this doesnt seem right.Any help would be great.
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Maybe drop the oil and check the condition of it. Nice new oil in there for a start.
    Hello from Under Down Under!
  3. The Following User Says Thank You to taslucas For This Useful Post:
    daves (25th November 2012)
    Expert BearGUST's Avatar
    Apr 2011
    Mornington Peninsula
    Mine is the same on a hoist but the LSD works a treat on/off road.
    I haven't looked into it a great deal but I believe they are a different style of LSD to most vehicles, I've read somewhere that they are a ramp-up design LSD as opposed to most vehicles which have a higher breakaway set up. Does anyone have more info on this?
    GUIII ZD30 Manual Wagon, OME 2" lift, 33" BFG AT's, Snorkel, Chip, 3" Redback Exh, Dual Batts, etc.
    KEEP OUR TRACKS LITTER FREE!
  5. The Following User Says Thank You to BearGUST For This Useful Post:
    thanks for your replies I droped about 500ml of diff oil and topped it up with nulon engine oil flush and will put new oil in after about 1000km's ,This is meant to clean the clutch plates,I will post the results when I have put the new oil in.It is defenately not working as good as it used to so hopefully this works.
    I put the new oil in and it is definitely better but is still not as good as it was.I will run the new oil for a while and will let you how it goes
    Is heaps better than it was has definately made a difference still might shim to get more out of it.
    Aug 2011
    North West Tas
    56 Post(s)
    Good to hear its a bit better now. Keep us informed if you go ahead with the shim. I read somewhere here that a 0.7 mm shim sold on eBay was too thick and had to be machined down a bit. I think it was nissannewby's mate......
    Tap, crackle, pop
  10. The Following User Says Thank You to taslucas For This Useful Post:
    daves (12th December 2012)
  11. #8
    Hardcore macca86's Avatar
    Jun 2011
    Brisbane again! whoo!
    What you described happens to lsd diffs so you can take corners. It requires a certain amout of force to be able to lock it up. Its a rather large force too. Next time you're out bush go through a bog hole get someone to watch id both wheels spin you're fine
    Such is the rule of honour.
  12. The Following User Says Thank You to macca86 For This Useful Post:
  13. #9
    Tap, crackle, pop
    It was ben-e-boy's mate and your correct lucas I think they had it knocked down to 0.4 with good results, the 0.7 basically locked the rear diff.
  14. The Following User Says Thank You to nissannewby For This Useful Post:
  15. #10
    Aug 2011
    North West Tas
    56 Post(s)
    Cool, thought I'd read it somewhere, cheers
    Tap, crackle, pop
