Results 31 to 39 of 39
Thread: Battery problems
  1. #31
    Hiya Ross,
    Yes ... the clips go on the Battery and then the Regulator will supply power to the "LOAD" terminals from the Solar Panel if the Output is high enough or switch to the Battery if the Solar panel drops down and use the Battery until it hits 11 ish volts then shut off.
    Anyway here is how to test your setup
    1. Measure the voltage at the terminals of the Battery
    2. Open the Solar Panel and put in the sun and measure the voltage at the battery Clips, don't let them touch and don't connect to the battery yet. (should be 14 volts or higher, might be Zero if it has a battery connected sensor, unlikely tho).
    3. Now connect the alligator clips to the Battery and measure the voltage at the Battery Terminals and check that the "Charging" LED is lit
    If the Battery is low the voltage should only be slightly higher in step 3 than in step 1 but it should def be higher EG 12.4 in step 1 then 12.7 or so in step 3
    It won't be like an Alternator where it goes up to high 13.s and stays there. Solar Regulators are current regulated not voltage
    DO NOT leave the battery connected with no Solar Power if you are recharging it as when the Soalr Power is unavailable the battery will power the Regulator
    Now... that Unit looks like their 15 Watt system to me. If it is that means in absolutely ideal conditions it will recharge your Battery at approximately 1 amp per hour... so if you have an N70 100 Amp Hour Battery and it is down 10 % then it will take 10 hours of ideal sunlight and angle to recharge it assuming absolutely nothing else is running.
    The system is designed to run a couple of lights OR a "small" Fridge IE a 40 litre or less off a battery by using battery power at night and topping the Battery up in the day so you need to start with a fully charged battery in that case.
    As a recharger, yes that will work but it will take yoinks... if the Battery is down say 30% it will take about 4 days
    As a battery "Keeper" IE connected to your fully charged vehicle Batteries and keeping them at 100% charge then Yes, it will do that quite well.
    Hope that helps matey...
  2. The Following User Says Thank You to the evil twin For This Useful Post:
    DX grunt (12th January 2011)
  3. #32
    BUMP...
    I'm still here Roscoe... lingering like that bad smell in the crapper that just won't go away...
  4. #33
    Jul 2010
    Waterford West Qld
    I think his solar battery in the PC has gone flat.
  5. #34
    Quote Originally Posted by Finly Owner View Post
    Hehehehe.... could be...
    ... Don't you make me come down there, Roscoe
  6. #35
    WA Wheatbelt
    23 Post(s)
    BUMP...
    I know, I know. lol Been really busy and tired from work, I start my 3 days off from Sunday, so I'll get to it then.
    I know you won't go away. lol
  7. #36
    Advanced mackayboi's Avatar
    I live in Central Queensland
    I would ask...
    have you charged the batteries successfully before with these same solar panels?
    Is there any draw from a electrical fault within the car?
    Try charging with a 240volt battery charger... if this works then the regulator might be out.
    My Patrol is My Vehicle of Choice.
  8. #37
    The solar charge regulator main task is to charge the battery and to protect it from deep discharging. Deep discharging could also damage the battery. Solar regulators also help to improve charge quality. It is generally recommended to use charge controllers with solar panels with the rated output of 5W or more. Furthermore, you can also bypass the battery and directly connect your appliances to the solar panel regulator In order to run them. Solar regulators are maintenance free. All you need to do is regularly check the connections, ensure normal air flow to the device, and avoid placing it in direct sunlight.
  9. The Following User Says Thank You to angeline For This Useful Post:
    patch697 (26th January 2011)
  10. #38
    Perth WA
    63 Post(s)
    Quote Originally Posted by angeline View Post
    Thanks mate, why not jump over to the Introduction section and introduce yourself, sounds like you are someone with a bit of knowledge about this sort of stuff.
  11. #39
    WA Wheatbelt
    23 Post(s)
    It's a brand new set up. I sussed it out and it's a German brand. Surely it can't have a flat battery already. It was a Xmas pressie.
