Results 1 to 10 of 13
Thread: Bleeding fuel system
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Hi Guys.
    I need some help. I replaced the fuel filter on my ZD30 and I have been unable to bleed it.
    Any tips?
    Regards Rodney
    How's the serenity boots's Avatar
    Sep 2011
    Have you removed outlet hose on filter housing and tried to prime with hand pump on filter housing or is yours different .
  3. The Following User Says Thank You to boots For This Useful Post:
    Yendor (1st December 2012)
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    I've tried it with the outlet off, I've even tried it with the fuel filter loose
    Sep 2011
    Do you have compressed air on hand ? could remove tank filler cap and force air in the tank - but you need to regulate the pressure and reduce considerably . remove hose from inlet side of filter to ensure flow if you consider this option ,
    Rodney I have done my fuel a heap of times in the last 6 months trying to sort out a problem. Solved! You should be able to take off the pump side of the fuel filter and put a plastic cup under the outlet and use the hand primer pump. Prepared to pump as much as 200 times if you have too!! It can take a heap to pull up from the tank. Don't give up!
  7. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    Fuel filter tight outlet off and ship loads of pumping should get it done.
  9. The Following User Says Thank You to MudRunnerTD For This Useful Post:
  10. #7
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    I feel like i've already pump it 200 times, my arms are about to fall off.
    Ok I will give it another go.
    Cheers mate
  11. #8
    Hard and fast mate will get it going initially. The other option is to put a facet pump inline so when you do a service you just hit the key let it pump.
  12. The Following User Says Thank You to nissannewby For This Useful Post:
  13. #9
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    When pumping and you put your finger over the outlet pipe how much pressure should you feel?
    Mine feels like there is hardly any if any.
  14. #10
    There won't be a lot until you get fuel up to it. How much fuel is in your tank? Do you have a compressor you could knock up a venturi and suck it through
