Results 1 to 10 of 11
Thread: patrol won't keep running
    Nov 2012
    Qld
    hi , hope i'm posting in the right section. my "85" patrol wont start unless i manually push the cable that goes down to where the control motor is but as soon as i release it again it just dies. any suggestion's
    Patrol God Bob's Avatar
    Oct 2010
    Pakenham
    47 Post(s)
    Not sure what Cable you are talking about but I would suggest that there is a bad connection on that Cable.
  3. The Following User Says Thank You to Bob For This Useful Post:
    panther (20th November 2012)
    Nov 2012
    Qld
    hi Bob , hope these pics help about the cable i'm talking about.
    Sounds like your idle needs adjustment.
  6. The Following User Says Thank You to nissannewby For This Useful Post:
    Haven't got a broken return spring or similar some where. doesn't sound like its to much of a big fix
  8. The Following User Says Thank You to threedogs For This Useful Post:
  9. #6
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Maybe try lubing up the cable with a bit of crc. Check for any sharp bends where the cable may have cut through the casing?
    Tap, crackle, pop
    Hello from Under Down Under!
  10. The Following User Says Thank You to taslucas For This Useful Post:
  11. #7
    Expert Diesel-Mate's Avatar
    Gold Coast
    Does it run if you have your foot on the gas pedal? It should'nt matter if you have your foot on the pedal or not, it should run. Try turning up your idle screw.
    Sent from my HTC Sensation XE with Beats Audio Z715a using Tapatalk 2
    TD42 turbo GQ - ironman snorkel - 4 inch flexy coils - 6" shocks - 3" straight exhaust - pyro and boost gauges in A pillar- uhf - winch - sunraisers - Bluetooth - spotties - front lokka
  12. The Following User Says Thank You to Diesel-Mate For This Useful Post:
  13. #8
    Nov 2012
    Qld
    i think there is something wrong at this end of the cable as it doesn't move or even make a sound when u turn on the key. someone said apparently you should hear it engage or at least see some movement
  14. #9
    Quote Originally Posted by panther View Post
    Ah the old SD33. I had one of those. That in the pic is what cuts the engine out. Check the electrical connection to that motor as when there is no power to that motor it pulls on the cable therefor shutting the engine down. That motor is activated by your ignition switch. Check all wiring and FUSES too.
    This is going by memory of 15 years back too so I may well be wrong.
  15. The Following User Says Thank You to mudski For This Useful Post:
    panther (21st November 2012)
  16. #10
    Nov 2012
    Qld
    thanks for all the suggestions everyone , i will check them all out and let you know if any worked. cheers
